ZC questions
Old Dec 23, 2002 | 11:55 AM
SIRX's Avatar
Default ZC questions
Ok, A friend wants me to drop a ZC engine and tranny into his 89 crx. It's a SI with a blown 5 speed and the motor is almost worn out. I've done many B series swaps but never a ZC, so from what I understand the motor and tranny is pretty much plug and play but he will need different axles as the ZC uses equal length shafts? What axles does he need and are the 5 speed zc trannys any good? Thanks for any help. Also his si ecu should work but is there a better one to use? Thanks also If I am missing anything let me know. Thanks again
Old Dec 23, 2002 | 02:47 PM
cr-x si's Avatar
Default Re: ZC questions (SIRX)
Check out this site it has everything there is to know about a zc swap.
I don't know what axles the zc tranny uses. But for the ecu, tell him to get a zc ecu or a 5-speed 88-89 integra ecu. i got my teg ecu at a junkyard for $50.
The si one will work, but the motor won't run to its potential.
http://dmoore.com/crx/zc.htm
h22_crx
Aug 30, 2005 05:59 AM
user 98292739
22
Oct 13, 2004 10:09 PM
VELOCITY R
Nov 8, 2003 06:32 AM
Cm91h22a
May 25, 2002 03:26 PM
honduh-guy
Feb 26, 2002 09:19 AM
