window will roll down about 3inches then it stops!?
It starting doing this the other day, when i try to roll my window down it stops and gets of track. The front of the window keeps on going but the back of it stops like it gest of track? this is the driver's side by the way, but can anyone help me or point me to the right direction? _Ben
no i haven made an attemp yet, i was wondering about that, but could it be because of weather stripping? i'll go pull the panels off right now. thanx _Ben
My passenger window doesn't roll down correctly and sometimes it'll come off the thigns that are holding it. It's hard to align it correctly.
broken man well i have the same prob when i force it to go down, and when i try putting it back up it wont go up. so its the regulator, i need a new one. plus my door panels were taken off b4 it started happening (process of installation of my tweeters) was that the problem.
Some of the teeth on the regulator are probably ground off. I had this problem on my last crx. It's a pretty easy fix once you have the door panel off, and I found the parts I needed at the pick a part.
8YourV8
Dec 13, 2010 10:09 AM
EnKidu
Oct 10, 2004 06:43 PM
fearless_dsm
May 24, 2003 11:15 AM
