legend/nsx caliper questions
Old Dec 22, 2002 | 09:15 PM
Buckshot's Avatar
Default legend/nsx caliper questions
well its time to get some new brakes on my gsr. im going to get the specR kit from fastbrakes. but i noticed some people getting the legend calipers. i asked brian about using the legend calipers with the specR kit and he said since the rotors are thinner the piston would be pushed 2.5mm farther out. he also said he sells the legend rotors but they are like 30 bux more a piece.
so now i have some questions:
do you think the 2 piston upgrade it worth the xtra money?
can i use the stock itr rotors and save some cash?
any insight would be greatly appreciated
Old Dec 22, 2002 | 09:55 PM
migs's Avatar
Default Re: legend/nsx caliper questions (Buckshot)
You have a GSR platform?
Old Dec 22, 2002 | 10:24 PM
Buckshot's Avatar
Default Re: legend/nsx caliper questions (Migs)
yes but upgrading to itr rotors and calipers
Old Dec 22, 2002 | 10:53 PM
MiraiZ's Avatar
I think there's a slight size difference in the rotors..you can get like washers or you can just buy the rotors for the legend and it'll fit
[Modified by MiraiZ, 6:46 PM 12/23/2002]
Old Dec 23, 2002 | 04:20 AM
Asahi's Avatar
Default Re: legend/nsx caliper questions (MiraiZ)
You can use R rotors no problem. Considering you can get legend calipers for the same or less than R calipers it should be worth it.
Old Dec 23, 2002 | 09:01 AM
Buckshot's Avatar
Default Re: legend/nsx caliper questions (Asahi)
sounds good
Old Dec 23, 2002 | 09:23 AM
Asahi's Avatar
should have added.
ALways check http://www.car-part.com for junk yard parts.
I got 2 legend calipers shipped for $80 with brackets, bolts and uncut brake lines.
Old Feb 3, 2003 | 06:52 PM
Buckshot's Avatar
well i just orderd my kit from fastbrakes...brian is a great guy
i got the blank rotors with axxis ultimate pads
im going to be using legend calipers..so i hope it wont be too much of a hastle putting them on my gsr..
what exaclty is involved in rebuilding a caliper? the ones i bought have like 120k miles..
[Modified by Buckshot, 9:41 AM 2/4/2003]
Old Feb 3, 2003 | 06:54 PM
JDM CTR '00's Avatar
GoldenONE
May 16, 2003 11:43 PM
sslude
Dec 22, 2002 08:59 PM
Veil_Side_
Jun 29, 2002 11:07 AM
