Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Hoosiers or wider Kuhmos
Old Dec 22, 2002 | 06:08 PM
Dropspeed's Avatar
Default Hoosiers or wider Kuhmos
I'm trying to figure out what would provide better grip for HPDEs in my modified ITR. The car already is cabable of impressive lap times on 205/50/15 Hoosiers but I see that the Kuhmo comes in a 225/45/15.
The question is, will a 225 Kuhmo perform the same or better than a 205 hoosier on a 7" wheel?
It would also be much more cost effective to use the Kuhmos if they provide the same level of performance.
Thanks Mattj
[Modified by Dropspeed, 10:09 PM 12/22/2002]
Old Dec 22, 2002 | 06:12 PM
phat-S's Avatar
Default Re: Hoosiers or wider Kuhmos (Dropspeed)
Is a 225 Kumho actually wider than a 205 Hoosier?
Old Dec 22, 2002 | 06:15 PM
phat-S's Avatar
Default Re: Hoosiers or wider Kuhmos (phat-S)
Ahh, I am hanging out with prostitutes and can no longer sleep eh? I kinda liked my Rex
Old Dec 22, 2002 | 06:18 PM
Dropspeed's Avatar
I don't know? Couldn't find any info comparing the two.
Mattj
Old Dec 22, 2002 | 06:30 PM
phat-S's Avatar
FWIW, my 225/50-14 Toyo Proxes are 2" shorter when stacked 4 tall than my 225/50-14 Hoosiers 4 tall (on the same 14x6 rims). That's about a 13 mm width increase by going w/ the Hoosier per tire. I'd see if you could get someone to compare the two first. I'd take Hoosier (-7 mm a la 205s) over the Kumho if I was looking for performance but that is me and I am going on others' feedback. I recall also that my rains 225/50-14 Toyos (on 5" rims) are marginally narrower (less than an inch across all 4) than a set of 205/55-14 Hoosiers (on 6" rims).
Old Dec 22, 2002 | 07:06 PM
Crack Monkey's Avatar
^ what he said.
Also, unless you are racing (and racing well, ie turning laps at the top of your field consistently), I see no need to pay for the Hoosiers. The Kumhos aren't that much slower and cost so much less. I put them in the same category as $2000 shocks - you might need them to win, but unless you're really that fast, you won't know the difference.
Old Dec 23, 2002 | 04:26 AM
celica73's Avatar
New User
Default Re: Hoosiers or wider Kuhmos (Crack Monkey)
I have both 205/50-15 Hoosiers and 225/45-15 Kumho's, both mounted on 15x6.5" rims.
The Hoosiers are every bit as wide as the Kumho's. The 225/45-15 Kumho V700 is actually pretty narrow, it was skinnier than my 225/50-15 Kumho Victoracers.
Scott
JonathanCD5
Sep 6, 2014 08:45 AM
HiPhOpHeADs
Sep 14, 2006 10:08 PM
Tomcat
35
May 19, 2005 04:19 PM
itr1244
Mar 17, 2005 12:07 PM
tFUnK
36
Feb 17, 2002 09:32 PM
