99 Si axles & int shaft for ef b16 swap. Will it work?
Old Dec 22, 2002 | 11:58 AM
WhiteDSM520's Avatar
Default 99 Si axles & int shaft for ef b16 swap. Will it work?
Any chance of these axles working for the swap? I know GSR ones fit if you take out the dust covers and use the gsr intermediate shaft. But howabout the 99 Si?
Thanks in advance.
Old Dec 22, 2002 | 12:26 PM
Jared's Avatar
Default Re: 99 Si axles & int shaft for ef b16 swap. Will it work? (WhiteDSM520)
You'll need to remove the dust rings inside the hubs and change your axle seals to the type used by the 99si, otherwise your axle seals will leak.
Starfury145
May 14, 2019 09:11 AM
Toe_fur
10
Jun 9, 2013 03:10 PM
jamesknightsi
Jan 18, 2006 09:47 AM
TypeR0207
Jul 28, 2001 02:03 PM
