Coil over Q
I drive a 5th gen prelude and I am considering three coil over setups for autoxing.
I know the Tein HA's are adjustable height and ride but they are pretty much out of the running since i live in southern Louisiana and they rust really quickly.
Does anyone know if the Tanabe Sustec Pro SS and the JIC FLTA2 are adjustable height?
Please do not respond with you opinion on which coil over is the "Best" because there are like 50 treads on that already. Thanks.
any coil-over with a threaded sleeve and adjustable spring perch is height adjustable....so to answer your question: yes
you live in southern louisiana? and why would rust be a problem? unless you drive your car on the beach and get salt water on it rust shouldn't be a problem for you at all.
Its like 80-100% humidity here all the time. I'd rathere spend an extra 4 hundred on a coil over with an aluminum sleeve and not worry about rust. Maybe I'll try the antisieze idea. Thanks.
'Lude01
Suspension & Brakes
May 2, 2006 08:07 PM
