Noise when turning!
Old Dec 21, 2002 | 03:41 PM
rivvin's Avatar
New User
Default Noise when turning!
When I'm turning and sometimes going over a bump at the same time, I hear a noise from under the hood. It doesn't sound like it's in the engine bay...possibly at the wheel area. But the noise is like a "clunk clunking squeek" noise. What could it be?
My car is stock.
Old Dec 21, 2002 | 03:43 PM
ucb's Avatar
ucb
Default Re: Noise when turning! (rivvin)
axle/cv joint is messed up and binding when turning, or your spring coils are rubbing
Old Dec 21, 2002 | 08:08 PM
rivvin's Avatar
New User
Default Re: Noise when turning! (UCBgsR)
how much will it cost to get those replaced? For the spring coils how do u stop it from rubbing?
Old Dec 22, 2002 | 05:48 PM
integobsession's Avatar
How many miles are on your car? My car made funny noises when I turned them... but not when going over bumps... It turned out that they just had to lubricate something... And viola no more noise.
Old Dec 22, 2002 | 05:59 PM
4doorRS5spd's Avatar
New User
Eliminate all possible things first, one by one. First, check to see if either CV boot is torn and or worn. I'm not saying that if the boot is not torn you don't have a problem with CV axle, but if the boot is torn, it's a good chance that you have a CV problem. Sorry, not thinking straight right now. Did that make since??
Old Dec 22, 2002 | 06:13 PM
bartek_b's Avatar
Default Re: Noise when turning! (UCB GSR)
"axle/cv joint is messed up and binding when turning"
check for CV boot dammage
Old Dec 22, 2002 | 11:44 PM
EvilIntegrationLS's Avatar
Default Re: Noise when turning! (mugen85r)
exactly, sounds like the common problem, so if it is, be prepared for some $$$ spending
WRTEG
Aug 18, 2004 02:15 PM
tuan...
Aug 2, 2004 06:31 AM
BLK99VTECR
Nov 10, 2003 01:16 PM
