Lazy turn signal.
Old Dec 21, 2002 | 10:05 AM
lloydhbales's Avatar
Default Lazy turn signal.
My '94 Honda Accord turn signals get lazy when the weather turns cold near 32 degrees. I turn them on and they won't start flashing for 10 or 15 seconds. They work fine in warmer temperatures. I replaced the flasher a week ago and the new flasher does the same way. All light bulbs are good. Thanks for any help.
Old Dec 21, 2002 | 04:14 PM
Chiovnidca's Avatar
Default Re: Lazy turn signal. (lloydhbales)
If they flash at a normal speed once they start, it's probably a bad switch.
Old Dec 22, 2002 | 10:05 AM
97accordex's Avatar
Default Re: Lazy turn signal. (Chiovnidca)
I have the same issue. It started when I changed out bulbs and light fixtures. The colder it is the slower they are and when systems warm up or I leave the directionals on for a while they speed up.
Chiovnidca may be right but I have read that it is also possible that the bulb may have too high voltage rating. Once a little current passes through the bulb and warms it up a bit the bulb element resistance drops. This in turn reduces the IR drop in the circuit, the flasher sees a higher voltage, and the flasher speeds up. Bulb resistance is really temperature sensitive. The lower the temp the higher the resistance. Once they warm up they are OK.
Just my theory. I have yet to verify it experimentally. Let me know if you work it out. I have seen several other people post with the same problem. A new flasher for the 97 Accord is about $30. New bulbs are about $2.
saintbhts
Sep 24, 2015 12:57 PM
Zeldred424
Lighting
Dec 27, 2012 06:04 AM
Noob@Cars
Jan 11, 2012 10:39 PM
rhughes
Oct 24, 2005 12:11 PM
