What injectors are 450cc??? from what cars?
What year cars have the famous 450 cc injectors everyone is getting.
i know the dsm turbos have them...5 speed i believe...
WHat other cars??? saab?? what year??/
90-94 Eclipse/Talon/Laser Turbo 5 sp. (#B450L)
95-99 Eclipse/Talon Turbo 5 sp. (#MDL450)
The automatic trans turbo cars have 390cc injectors (#B390L)
Here is some RX-7 injector info:
84-85 GSL-SE
has 2 low impedance (1.5-3.0 ohm) 680cc injectors. both are on the primary fuel rail, there is no secondary fuel rail. Uses pulsation dampener. They use the Bosch style plug.
86-87 N/A
has 4 injectors. 2 on primary rail, 2 on secondary. All are 460cc low impedance (1.5-3.0 ohm). The part number for these injectors is 195510-1350. They use the Bosch style plug.
87 TII
uses 4 550cc injectors. 2 in primary, 2 in secondary. All are low impedance. The part number for these injectors is 195510-1370. They use the Bosch style plug. GSL-SE injector are a good upgrade for the secondaries. They will plug right in, but your computer will cause you to run rich under boost. The stock ECU number is N332-18-880.
88 TII
uses 4 550cc high impedance (11-15 ohm) injectors. The part number is 195510-1680. They use the Bosch style plug. GSL-SE injectors can be used as an upgrade, but you must wire a 10 ohm resistor in line on the harness. The stock ECU number is N333-18-880.
84-85 GSL-SE
86-87 N/A
87 TII
88 TII
