Oil pressure sensor
Old Dec 21, 2002 | 08:36 AM
zCivic's Avatar
Default Oil pressure sensor
Got a CEL 22 Oil pressure sensor. It only sets the code every once in a while. Wondering if there is a test for this to see if the sensor is bad. When you try to get V-tec to engage will it set it? Need to trick the ECU to see if it will throw it again. Got it reseted. What will cause this to flip out.
Old Dec 21, 2002 | 08:56 AM
KTeller8's Avatar
Default Re: Oil pressure sensor (zCivic)
you asking us questions or telling us your answers
you want to trick the ecu.. reset it....
Old Dec 21, 2002 | 08:59 AM
urbanlegend21's Avatar
New User
Default Re: Oil pressure sensor (KTeller8)
check your oil level on the car........
if it is on the line add a little
if that doesn't work check and clean your VTEC solenoid
Old Dec 21, 2002 | 09:34 AM
zCivic's Avatar
Default Re: Oil pressure sensor (urbanlegend21)
It was a question. Was wondering if there is anyway to cause it to throw it again?? Test drove it for about 15mins and got V-tec to engage but no codes so hopefully it was only a fluke.
KTeller8's Avatar
drop your pan and see if anythings there
check your line and see if you tube is bent
si90rex
Honda Civic (2001 - 2005)
Jun 20, 2014 06:57 PM
vladd
Jul 10, 2008 05:03 PM
shaylude
Jul 13, 2007 12:44 PM
esoterEK..
Apr 10, 2005 07:00 PM
