turboa6 or b16?
It depends on what you want out of the car.
Need more bottom end? b16. Still pulls hard up top... well, pulls harder all the time.... more reliable, as previously stated...
Want that neat "psssssshhhhow" sound? Go turbo. The A6 is a great motor to turbo, cause it won't cost you 1/5th the price of a b16 if/when you blow it skyhigh.
I'd go turbo, personally. It's more fun to tune a turbo than sit there and look at the plug and play b16
Just my opinion.
Just my opinion.
Nothing like the "psssssh". I have a B16A but if I could turn back time I think I would choose the FI route. Just make sure u build up ur engine good b4 u put on boost.
IMO b16 is WAY WAY over-rated. i would go with the A6 turbo. i have z6 turbo with stock internals and all... (for now) w/ greddy kit. granted i only drove it 3 days before it totaled (head-on
) . but when it goes in the hatch i will have ditched the POS black box and going with some hondata stuff!!!!!! but definatly no b16..
thanks for the replys..but never made a decision yet..cause right now my a6 has a bad ring in #2cyclinder...dunno i would love to here the psssh..but also would love to tell people that i have a b16
me personally i am goin A6 turbo, i dont like the b16s just for the fact that you dont get a good powerband till vtec. i just want to roll up to somebody and them want to race and tell me that they have a b16 in their car so i can laugh and drive away, i am gunna build the motor and use a full stand alone engine management system and raise the compression with ALOT of boost. so go A6 turbo
while u do it... check this place for some info on what car u can take the intercooler
http://www.turbomustangs.com/intercoolers.htm
[Modified by dEF juNKie, 6:10 PM 12/21/2002]
counter productive?
This is a very good friend of mine, making 640hp to the wheels, with.. VTEC! OMG yes its true VTEC & TURBO DO WORK? hmmm
Best run 9.7 @ 142
Its called dialing out overlap with cam gears, its actually pretty simple to do.
"Turbo a nonvtec b16" So simply unplug the vtec solinod and turbo it? ya that will be real fast..
I swear to god...
Jeff Frank
Best run 9.7 @ 142
I swear to god...
Jeff Frank
my a6 turbo project that im doing will cost just under or maybe a bit above what a b16 swap would be, and its gonna hands down whoop the b16. even if the b16 had alot of bolt ons
Example, my 89 si d16a6 running a custom T25 setup (6-7)psi ran 14.1 @ 101 mph, My very close friend who has a B16a in a 88 si with Intake and exhaust ran consistant 14.0's. the cars were very close, we use to race all the time. The turbo a6 will have more useable torque on the street though, and may seem faster.
Jeff Frank
You would be suprised, they will be pretty close (depending on how much boost you are running ofcourse) but we have done various turbo setups, and lots of swaps. Honestly a Turbo D16a6 running 6-7 psi is pretty comparable to a B16a with barley any mods.
Jeff Frank
Jeff Frank
Guest
Posts: n/a
I swear to god...
Jeff Frank
I swear to god...
Jeff Frank
and like you said
I swear to god...
on the other hand. tell your buddy im sorry that he spent thousands on his turbo setup when it only gave him a .54 advantage over the fastest NA B16 (and yes its non vtec http://www.ericksracing.com).
[Modified by TorteX, 5:43 AM 12/22/2002]
Guest
Posts: n/a
turbo a nonvtec b16
vtec and boost = counter productive
Damn Abaz, you beat me to the punch. But in response to that, bwah hahahaha!!!!!!
in responce to your responce AJIDHSWGNSUGAHAHAHAHAHHAHAHAHAHAHAHAHHAHAHAHAHAHHA A
I'd go the turbo route. You can always turn up the boost, right?
Turning a B16 into non-VTEC is a set of cams away. I bought the roller rockers from Crane though. Very nice less noise from valvetrain and it revs considerably faster. Expensive though. Now I'm broke.
I believe Jeff from importbuilders has stated on this board that he has seen over 100 hp loss from disconnecting the vtec solenoid on a built boosted motor.
