ZC Dyno charts
Old Dec 20, 2002 | 04:51 PM
Hondasaurs's Avatar
Default ZC Dyno charts
Does anyone have pics of their dyno charts on their DOHC Natrually Aspirated engines? I have an Apex-i AFC and I'm looking for some graphs so I can set up my controller. Thanks.
Old Dec 20, 2002 | 06:27 PM
CRVRX's Avatar
Default Re: ZC Dyno charts (ZC_CRX)
Just save you some time. Dyno your car , every car is different. Dyno your car with a wide band and then you can taylor it to your needs.
Old Dec 20, 2002 | 08:01 PM
chef's Avatar
i've got one at home. i posted it on here awhile back with a b16 with comparable mods overlaid on it. i'm at my mom's house, then crashing at my girls, i'll try to find it tomorrow and look for this thread. the mods on this zc included neuspeed 4-2-1 and short ram and dynomax muffler.
Old Dec 21, 2002 | 08:53 AM
Hondasaurs's Avatar
Default Re: ZC Dyno charts (CRVRX)
No one around here has a Dyno......i'm just looking for an idea where the power bands are.
[Modified by ZC_CRX, 7:01 PM 12/21/2002]
Old Dec 21, 2002 | 01:04 PM
koshir's Avatar
Here is mine civic D16A9 dyno it has tuned ECU, racing header, full racing exhaust, K&N CAI....
Old Dec 21, 2002 | 01:07 PM
Urban Business
Guest
Posts: n/a
Default Re: ZC Dyno charts (TypeKoshiR)
d16a9 isnt a zc
Old Dec 21, 2002 | 01:37 PM
crx(gator)'s Avatar
Default Re: ZC Dyno charts (TorteX)
its pretty dam close to it...just a little less compression...
Old Dec 21, 2002 | 02:25 PM
Urban Business
Guest
Posts: n/a
Default Re: ZC Dyno charts (crx "going j-oem" gator)
and a different cam
different rods
different crank
otherwise they are similar
Old Dec 21, 2002 | 02:46 PM
crx(gator)'s Avatar
they make like ~5 hp less...they are so dam close, do you have proof of the different crank and rods...i would like to see some pics of that...
Old Dec 21, 2002 | 06:26 PM
AbaZ's Avatar
Sorry, same rods, Same crank
Same bore and stroke as well
75.0 x 90.0
Differnce is made up in cams & ECU.
Jeff Frank
Old Dec 21, 2002 | 09:07 PM
keithv's Avatar
Default Re: ZC Dyno charts (AbaZ)
i'll try to scan mine in on monday...
Old Dec 21, 2002 | 09:16 PM
CRX-RX's Avatar
75.0 x 90.0
Jeff Frank
I just got back a ZC I dropped off at the machine shop, and they didn't tell me they crushed a piston, but they replaced one with a P26. It's an exact match for the JDM pistons. I guess I could just stop wondering what it is and ask my freind who works at the acura parts counter if it's an 89 teg part, but I'm assuming so.
Old Dec 22, 2002 | 12:33 AM
Urban Business
Guest
Posts: n/a
Default Re: ZC Dyno charts (CRX-RX)
http://community-2.webtv.net/agReziv...siR/page9.html
now go get learned
zc is not a d16X
a zc is a zc
Old Dec 22, 2002 | 07:13 AM
Hondasaurs's Avatar
Default Re: ZC Dyno charts (breaka_1_9)
Thanks
Old Dec 22, 2002 | 07:26 AM
89civicdx's Avatar
Here you go...header, stock airbox with K&N, 2 1/4 midpipe,chipped ecu, stock muffler it made like 8hp more with no muffler but I don't know where that dyno is...I'll have to look for it.
[Modified by 89civicdx, 8:28 AM 12/22/2002]
Old Dec 22, 2002 | 07:35 AM
koshir's Avatar
Default Re: ZC Dyno charts (89civicdx)
As I know my engine is ZC it's a:
Civic 1.6 16V HB
D16A9 JDM engine with 130hp & redline on 7300rpm(original)
Everyone I know in USA said that that is a ZC engine, so now I'm little confused!
Old Dec 22, 2002 | 07:40 AM
Hondasaurs's Avatar
If it has "ZC" stamped on the engine block its a ZC. If not then its not a ZC.
Old Dec 22, 2002 | 02:38 PM
crx(gator)'s Avatar
you just owned yourself with that link...the rods are different in the brown top and black top versions...not the zc and the d16a9...
"Now, the diffrences betweem the motors USDM/JDM brown top v. USDM/JDM black top is the following.. Brown Top: lower compression pistons, thicker (stronger?) rods and of course vacumm advance. Black Top: higher compression pistons, lighter (more rpm?) rods, better intake manifold than the brown top, and newly styled electronic advance. "
and no where does it talk about the crankshaft...
Old Dec 23, 2002 | 05:34 AM
keithv's Avatar
here is my dyno plot as promised. ignore the 1st dyno numbers as they are not mine. the dyno operator added the wrong persons dyno numbers to my plot.
my mods are:
- stock interals zc (with 1000 mi on the rebuild)
- stock flywheel lightened by ~2lbs
- stock intake with resonator box removed
- 2.25" "custom" exhaust using the zc exhaust manifold and cat
http://www.geocities.com/breaka19/POS/zc_dyno.jpg
<u>note:</u> you will have to copy and paste the link into your browser.
Old Dec 23, 2002 | 02:41 PM
Hondasaurs's Avatar
Thanks, I appreciate it!
drprince89
Jan 4, 2005 12:12 PM
90crxzc
12
Aug 23, 2003 11:09 PM
AMChev
15
Aug 19, 2002 07:28 AM
