Where do u place your MSD 6al box in a GSR?
Old Dec 20, 2002 | 01:16 PM
LSVTEC408's Avatar
Default Where do u place your MSD 6al box in a GSR?
i do not know where to put my MSD Box, damm abs is in the way, and i got a skunk2 mnifold, so its hard to put it in the firewall, any ideas besides relocating the battery to the trunk!
Old Dec 20, 2002 | 03:51 PM
drewspeed's Avatar
Default Re: Where do u place your MSD 6al box in a GSR? (LSVTEC408)
Not the safest or best place but some do wire it inside the car ie. glove box, or under passenger seat. Just ideas but yes it is best to find somewhere in engine bay. Good luck.
Old Dec 20, 2002 | 04:07 PM
PM-Performance's Avatar
Default Re: Where do u place your MSD 6al box in a GSR? (drewspeed)
glove box is a no no , it will heat up and eventually fry
i had no room inmy bay so mines is under the pass seat
Old Dec 20, 2002 | 05:17 PM
LSVTEC408's Avatar
Default Re: Where do u place your MSD 6al box in a GSR? (itr206)
u think its safe on the passenger side by the ecu on the floor, i was gonna drill it thereand then put my floormat on top, is this a good idea.
Old Dec 20, 2002 | 05:49 PM
jdmotorsports's Avatar
no, you want to keep the case exposed to air. if you dont have a cai you can mount it where your air resonator is. otherwise you can ditch your cruise control and put it there.
Old Dec 20, 2002 | 06:03 PM
Default Re: Where do u place your MSD 6al box in a GSR? (jdmotorsports)
yea, gotta let the heat dissapte
Old Dec 20, 2002 | 09:10 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Good question. I'm in the same boat. I ended up making a make shift plate and mounted it to the bolt location that the OE intake arm mounted to by the ABS unit. I'd eventually like to re-mount it in the fender well area to keep it out of the way.
What I should do is take it out and sell it since I don't really make enough power to warrant one. But i got it for cheap and I wanted to see if I felt any difference. And except for a bit better idle, I feel no diff. I'm just too lazy to take it all apart again.
Good luck!
Old Dec 20, 2002 | 10:23 PM
obd2gsr's Avatar
Default Re: Where do u place your MSD 6al box in a GSR? (Gee3)
if you can't fit it inside the engine bay (i wasn't able to, either), you can mount it under the passenger seat as long as air is able to go underneath the box. the best way to do this is to buy a mounting kit, such as
http://www.kodiakmotorsports.com/24500.jpg
or you can make your own by going to home depot and do it yourself. that's how i mounted mine underneath my seat. good luck! and hope this helps you out!
Old Dec 21, 2002 | 04:35 PM
JBONES's Avatar
my digitail6 is located inside the car on the passenger side near the fire wall behind the carpet...........it mounts nicely there....
Old Dec 21, 2002 | 05:45 PM
AlphaKennyWun's Avatar
Default Re: Where do u place your MSD 6al box in a GSR? (JBONES)
mine wsa there too
*Boostwerks*
Feb 23, 2005 02:01 AM
K20DC2R
Apr 30, 2004 05:39 PM
Rod.
Apr 8, 2004 09:53 PM
vactor
Sep 9, 2002 10:48 AM
Duck Sauce
Jan 12, 2002 07:56 AM
