anyone know if they make a copy of the mugen integra wing for a 99-00 civic coupe
that's all i need to know, and if anyone has a pick of it, just to get an idea of what it would look like, i'd appreciate it. I'm not really into wings, but there's this R by my job and i love how it looks, so i wonder what it would look like on my coupe. Yes, i also have more than enough power to back it up.
Guest
Posts: n/a
http://www.kingmotorsports.com
Its a four door wing but I seen a guy on clubsi put it on a ebp. it looks bad ***.
damn, that is pretty hot, i think it would look better that the higher integra wing too. Thanks for the pic. I'm normally not into wings, but for some reason that one and the integra do it for me.
the mugen integra wing can be modified to fit on the coupe trunk... can't find the pics right now but you don't need to find a copy... the integra one can be slightly modded...
thanks wizebanana, you wouldn't happen to know what needs to be modified on the wing would you.
???? The Mugen wing is made for civic, not Integra.
The mugen wing will fit both civic and integra without mod.
I talk there for I am dumn !!!
some people The Mugen wing is "made" for the Teg but will easily fit but you must remove some of the stuctual bracing ( just enough to get the nuts on about a 1in hole for each bolt dont forget washers
) because some is in the way when you mount it and its adjustable so the angles wont matter. Hope this helps ya'll
[Modified by PornstaR16L, 4:19 AM 12/22/2002]
thanks pornstar16l, now i'm kinda looking at the one for the 4door civic too. It looks low enough and i like that cause i'm not sure how high the teg wing would be.
duh hu hu shiu jajfj; lgkja
some people
The Integra mugen wing for integra looks similar to a type r wing.
actually if you read the post right, you would have known that i was asking about the mugen integra wing and if it would fit the civic. It's obvious that the wing pictured above is for a civic since it's on one.
if you read his original post he was referring to a mugen wing he saw on an R (obviously on an integra)...
someone else posted the ferio mugen wing...
OnePointFive
Apr 12, 2007 12:39 AM
BlackCivicHatch
Jan 13, 2004 04:09 PM
