Please Help, B16a VTEC problem!!!!
Old Dec 19, 2002 | 10:38 PM
Rywire's Avatar
Default Please Help, B16a VTEC problem!!!!
Hi, I recently (done for a month or so) completed my b16a swap, and cant seem to get the vtec to kick it. I have a 21 code, (vtec solenoid). So, my honda tech teacher manully activated vtec, and verified the solenoid is ok, we also ran a volt meter to each end of the vtec wires, (ecu side to solenoid side) and there was continuity. I also tried another computer, and the same code poped up. Please help! Thanks, Ryan
PS,i had a pr3, but now i am running a pwo. the chech eng light comes on right away also. also, is it cool to drive it like this? ryan
Old Dec 19, 2002 | 10:59 PM
slowpokesi's Avatar
Default Re: Please Help, B16a VTEC problem!!!! (droppedcrxsi)
take your ecu to honda and get the vtec 1.9 upgrade, that should take care of it
[Modified by slowpokesi, 8:00 AM 12/20/2002]
Old Dec 20, 2002 | 03:52 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Is your oil pan dented?
that could cause a drop in oil press and VTEC won't work.
Make sure the VTEC sol is wiired to the correct place on the ECU.
If you get that code right away, and the solenoid is OK, then the problem is on the connections.
Old Dec 20, 2002 | 04:35 AM
ricodemus's Avatar
Default Re: Please Help, B16a VTEC problem!!!! (Spaceballs the lunch box)
yeah, remember that the pins count odds on the top row and evens on the bottom. If you wire them wrong by counting them straight across (1,2,3,4,5..), the wires you replace will still let the car run but vtec is obviously not hooked up. Check your wiring again.
Old Dec 20, 2002 | 06:49 PM
Rywire's Avatar
Actully the oil pan is dented! I believe I wired it right though. I will have to check it out. Ryan
Old Dec 20, 2002 | 08:29 PM
riceboy's Avatar
its gotta be an oil pressure problem, have you checked the oil screen and passage through the block?
Old Dec 21, 2002 | 09:44 AM
Malgerus's Avatar
Default Re: Please Help, B16a VTEC problem!!!! (riceboy)
No, it's not an oil pressure problem. If there are any problems with the VTEC soleniod or the connections, the ECU will detect it IMMEDIATLY... as soon as you turn it on you'll get a check engine light. If it was an oil pressure problem it would take a while to for the CEL to kick in. Plus, the idiot light would probably come on.
Old Dec 21, 2002 | 10:21 AM
JALOP B16's Avatar
Default Re: Please Help, B16a VTEC problem!!!! (Mr. S)
Yeah and if it eas the oil pres you would be getting a code 22
Old Dec 27, 2002 | 12:30 PM
Rywire's Avatar
Default Re: Please Help, B16a VTEC problem!!!! (JALOP B16)
Yeah, the code is 21, not 22(oil press). I assume it is a connection, I checked hasports site, and verified that the connections to the ecu were correct. Same thing. I am stumped. So, the only thing it could be is the solenoid, connecting wire, connections between them, and ecu correct? Thanks. Ryan
CRXHFB16
Aug 10, 2007 02:29 AM
686_ef
12
Feb 13, 2006 08:31 PM
MugeNinja
Dec 29, 2005 09:50 AM
Gunns
13
Jun 1, 2004 11:15 PM
flat-blk-HB
Oct 5, 2002 09:28 AM
