Xmas gift for her... (56K warning)
I went to toronto and picked up a set of Phillips HID..
and some random pics with my friends.
S2K HID VS mine
What could this be??? UPS man dropped it off while i was away.
I cant wait to see this pipe installed
i will post review on the pipe with my spoon n1 after it's installed.
HID review:
No need to say a word. ..It's just fugging beautiful and BRIGHT
---Thx to trevor and a&j
[Modified by itr1244, 6:49 AM 12/20/2002]
What could this be??? UPS man dropped it off while i was away. I cant wait to see this pipe installed
HID review:
pics of "the bottle neck"
Should i remove it??
if i do. how can i connect the pipe together?
why's the bottle neck there for??
[Modified by itr1244, 7:47 AM 12/20/2002]
it's there to make our lives more difficult.
I was pissed when I saw mine too. I took mine to SMS, but he is right down the road from me. You need to cut it, then weld on a new gasket so it will match up with your N1. A muffler shop can most likely do this.
edit - your avatar is getting old...go back to yk100.com and get us some new blood
[Modified by Ross, 5:37 AM 12/20/2002]
[QUOTE]pics of "the bottle neck"
QUOTE]
Looks like they weld on an adapter to make it fit the USDM cat... looks like you might be able to cut the 3 welds on the cat side of the flange with a dremel abrasive wheel. Then carefully smooth the mating surface and not have to have another flange welded on...
For those of you who use the airlines... I was manufacturing aeroframe at age 19... so alot of the planes in the air right now have my acid etched stamp on them... makes you feel safe don't it?
QUOTE]Looks like they weld on an adapter to make it fit the USDM cat... looks like you might be able to cut the 3 welds on the cat side of the flange with a dremel abrasive wheel. Then carefully smooth the mating surface and not have to have another flange welded on...
I just orded the same kit from Trevor. How did you're new HID's compare with the S2K's as far as brightness and color? I know the S2K's are flat out badass. In the pic they look really close.
actually mine looked more bright than my friend's 2002 S2K
but S2K makes more "blue" in different angles..
already??? it's almost end of december man hee..
it hasnt snow in vancouver??? damn man i miss vancouver like ish...
Trust me.. vancouver is the best place to chill
damn snow out there already
Nice pics tho
Nice pics tho
..Trust me.. vancouver is the best place to chill
