Will these Volks work on our R's
Hi everyone, i was wondering if 17X 7.5 +48 offset work on your Type R's? It's the Volks LE-37's? Is +48 offset right? Or does it have to be +40?
well.. don't know if it will rub or not.. but i tried to calculate on what the difference would be.
it will stick out 17.05mm more on the outside than stock 15x6 +50, and will be 21.05mm more on the inside.. so.. i'd measure first to be sure
it'll work if you get like a 3-5 mm spacer, but you don't want that, the correct offset should ne 43mm-45mm...48mm will work on the RSX's...hope that helps...
peace
peace
