cr-x Si-R headlights wiring...anyone know how?
There are 3 wires on the jdm bulb (H4), simply take the lead wire from your high and low beam and 1 for ground. To take it out, pull the rubber insulation and you'll see a metal clip that holds the bulb, push the metal clip in and it should release from its hinge. Then you can just slide the bulb off.
J Money
Dec 21, 2003 12:24 PM
Bodman
Oct 18, 2003 09:26 PM
