lowering question for a 2000 SH
Im going with ground control coilovers and koni yellow shocks with some 18 or 17 inch motegi mr7's. i think that would drop it about 1.5. would i need a camber kit????
Allow me to point you to the Ingalls (www.ingallseng.com) and Specialty Products (www.specprod.com) websites. They both offer ther EXPERT advice on when and why you need kits for your car. With that said the general rule is that for EACH 1" of drop the Camber will go negative by ~0.75 degrees from where you start. Since Honda says the 5th gen front needs to be at ~0.0 +/- 1 degree, you will be close to the outer limit. The rear of ALL 5th gens have a range of +0.3 to -1.8 degrees and should be closer to -0.5.
Let me warn you that kits for the SH are not as easy to find as the Base-just call the manufacturers including (www.northstarmfg.com and you will find kits for thefront. The rear uses either Ingalls or Specialty adjustable anchor bolts.
92integraVTECgsr
Suspension & Brakes
Aug 22, 2005 05:39 PM
