anyone ever used a sump pump to pump oil?
Old Dec 19, 2002 | 03:16 PM
TurbothisLS's Avatar
Default anyone ever used a sump pump to pump oil?
i need to find out where to get a sump pump for my friend's maxima.
the turbo sits lower than his oil pan, so he needs to drain oil to a can/resevoir below the turbo and use a sump pump to pump it from there into the oil pan.
thanks
Old Dec 19, 2002 | 03:41 PM
Default Re: anyone ever used a sump pump to pump oil? (TurbothisLS)
anywhere to try?
Old Dec 19, 2002 | 03:57 PM
does anyone know anyplace online or around the DFW area that might sell these?
Old Dec 19, 2002 | 04:21 PM
how about an electric oil pump?
anywhere to get one?
Old Dec 19, 2002 | 04:35 PM
dbman96's Avatar
New User
I would start looking at Jegs or Summit catalogs - this stuff isn't uncommon for big-engine domestics.
Old Dec 19, 2002 | 04:39 PM
Default Re: anyone ever used a sump pump to pump oil? (dbman96)
k cool.
would i search for an electric oil pump?
or what would i be looking for exactly?
Old Dec 19, 2002 | 07:58 PM
tony1's Avatar
I may be able to get you something. Give me a call at the shop and i'll check around.
Tony
972-278-9744
Old Dec 19, 2002 | 09:52 PM
AR Fab's Avatar
Default Re: anyone ever used a sump pump to pump oil? (tony1)
we use a simple electic pump on our setup...it scavanges the oil out of the turbo....lots of road racers with turbo cars use them....I dont think it even cost more than 75 bucks from Summit....Here at home I dont know the part number...but if you call me at the shop, ill tell you what the part number is....There is also very expensive pumps out ther too...no need to use them..
Howard
540 955 2263
Old Dec 20, 2002 | 04:12 AM
RGAZ's Avatar
New User
Look at the dry-sump oiling systems in Summit. The dry sump system can have an electric pump. I've never done it, but someone told me you can use a power steering pump (but why?).
Randy
BlUAc
Aug 6, 2007 09:04 PM
