max boost with 11:1 compression
Old Dec 19, 2002 | 03:10 PM
gtconcepts's Avatar
Default max boost with 11:1 compression
What is the max boost i could run with 11:1 compression , running a 255lph fuel pump 8:1 vortech fuel press regulator 550cc injectors and a safc....
thanks
Gilbert
Old Dec 19, 2002 | 04:16 PM
*Boostwerks*'s Avatar
Default Re: max boost with 11:1 compression (gtconcepts)
Simply put:
There are to many variables to give you a specific answer.
sorry.
Old Dec 19, 2002 | 04:26 PM
gtconcepts's Avatar
Default Re: max boost with 11:1 compression (Bryson)
would 10psi is good? or should i start from 6psi and tune it up??
Old Dec 19, 2002 | 04:30 PM
len's Avatar
len
Just like the other guy said, there are too many variables...
You can blow it up at 3 psi in a very lean condition.
Old Dec 19, 2002 | 06:11 PM
gtconcepts's Avatar
Default Re: max boost with 11:1 compression (len)
so I better lower the compression 9:1 then, i have hear of some integras type r running high compression with boost on stock internals.. my understanding is as long as there is enough fuel and a good intercooler chances of blowing are very low.. like i mention before im not running stock fuel system , im running enough fuel to support 330hp on a 4 cylinder application..wher can I find information on this turbo type r...
thanks
Gilbert
monster_c
Apr 6, 2012 02:14 PM
Coppertop
Aug 25, 2005 12:18 PM
94TealGSR
Jun 5, 2003 08:54 AM
H22coupe
Jun 2, 2003 10:13 AM
philo
Nov 29, 2002 11:31 PM
