Wheel question?
Old Dec 19, 2002 | 02:01 PM
itr449's Avatar
Default Wheel question?
I found a set of wheels that i really like they're 17x7 with a 38mm offset. Will i run into any problems with these wheels? I'm also planning on doing a set of zeal b2's at the same time so the car will be dropped. Will i be rubbing or will this set up work alright? Thanks in advance
Old Dec 22, 2002 | 09:54 PM
1CoolR's Avatar
Default Re: Wheel question? (itr449)
I've run pretty much the same setup using 205x40x17 A520's, which had a square shoulder, and was lowered with H&R springs, roughly 1.5" lower, and had no rubbing or clearance issues.
However, I seem to have noticed more camber wear on the fronts with 17's, than when running 15's or 16's.
Old Dec 22, 2002 | 11:24 PM
vtec.dc2's Avatar
https://honda-tech.com/zerothread?id=364614 - this will tell you how much it will stick out..
Double Agent
May 16, 2012 08:00 AM
romeo_f
Feb 18, 2011 12:07 PM
ITR0842
May 23, 2008 08:36 PM
wacrxguy
39
Oct 27, 2005 07:38 PM
DC2 to AP2
Sep 13, 2005 08:54 AM
