Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Sparco seat bracket questoin
Old Dec 19, 2002 | 01:46 PM
Madracer1's Avatar
Default Sparco seat bracket questoin
Is 1992 Civic base model and up and the 95 GS-R bracket the same?
Thanks in advance!
Rado
Old Dec 19, 2002 | 02:16 PM
RineRacing's Avatar
Default Re: Sparco seat bracket questoin (Madracer1)
From what I have heard, the Civic and Integra have slightly different holes.
HOWEVER, be careful what seat you're mounting to the Sparco floor base. In case Sparco didn't warn you (which they never do), the Sparco Floor Base is only designed to work with bottom mount seats or the Sparco Evo (even that one doesn't always fit right).
Old Dec 19, 2002 | 02:20 PM
Madracer1's Avatar
Default Re: Sparco seat bracket questoin (Geratol)
Well I am mounting a bottom mount seat on a floor bracket that says on the bag 92 Civic and up and the holes dont match worth sh*t so I was wondering if I should call to get a new bracket if they are different!!
Thanks again!!
Rado
Old Dec 19, 2002 | 02:52 PM
Cal's Avatar
Cal
I got one recently for an EK. It says 92 civic on the bag aswell. I was told they are all the same as the only holes that are differnt are the ones on teh bottom of the seat. Not the base mounts. So if you are using a Sparco seat you should have no problems.
Cal - Who has never sat in the seat let alone installed it, due to not having a cage yet.
Old Dec 19, 2002 | 03:33 PM
RineRacing's Avatar
If the bracket intended for a 92 civic isn't fitting in your integra then it would be safe to assume that the civic and integra brackets are not the same.
Calling to get the correct floor bracket is up to you.
Old Dec 20, 2002 | 04:36 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
the 92-95 civic and 94-01 integ have different crackets. the front bolt holes and rear bolt holes are of the same width, but the offset front to rear is different. frankly, all the brackets out there are garbage for side mounts seats. all of them. yep. every one.
personally, i buy wedge engineering brackets (for their fit, and i don't have to have the car in front of me for a totally custom bracket), and modify (reinforce, and add harness rods) but, that's just me. good luck.
89hatcher
May 29, 2007 08:02 AM
GR_DC2
Oct 12, 2005 06:14 PM
GR_DC2
Oct 12, 2005 09:50 AM
ShowSpeed
Oct 10, 2002 07:32 PM
