bent valves at track!
Old Dec 19, 2002 | 02:46 AM
N1Spec's Avatar
New User
Default bent valves at track!
hi guys...... had an aweseome day at the track today. Till i fucked up that is
last session out, pushing too hard i mishifted to 3rd instead of 5th, i saw the tacho spike to 10,200rpm, then my motor stalled.... i knew i stuffed something up at that stage. Car is still driveable however it would stall if you dont keep the revs up, did a compression test and no.4 cyclinder was way down, it was showing 150, while the otehes were around the 225 mark. My mechanic reckons i bent an exhuast valve and said it shouldnt be too hard or too costly to fix. He said that only that 1 particlular bent valve will need replacing and of cos the headgasket.
Im under the assumption that if you bent valves you also damage the pistons and valve springs? am i correct? or is mine a minor case? could there be other unforseeable damage to the engine thats not apparent yet?
cheers
Old Dec 19, 2002 | 03:55 AM
GZR4DR's Avatar
Default Re: bent valves at track! (N1Spec)
Just replace the valve, 3 angle valve job, new headgasket, and your set to go. Consider yourself lucky you didnt break the valve. That would mean time for a new engine. Shouldn't cost to much for what could of happened.
Old Dec 19, 2002 | 04:05 AM
Fuuma0083's Avatar
Default Re: bent valves at track! (GZR4DR)
you can't fully inspect the damage till the head is off, but i've seen this happened alot with people with 2 valves needed to be replace to a engine heading for the junkyard.
Old Dec 19, 2002 | 04:53 AM
Euro98ITR's Avatar
cheers
When something like this happens ... isnt there the revlimiter? assuming this guy has a revlimiter.
Reid's Avatar
Global Moderator
Default Re: bent valves at track! (SF-ITR)
The revlimiter is useless on misshifts.
Old Dec 19, 2002 | 06:14 AM
Russ713's Avatar
dAng!
Default Re: bent valves at track! (Reid)
true, the rev limiters are EXTREMELY useless. Want to see proof? Check the link in my sig.
Haunt's Avatar
The wheels push the motor over the limit...even though the fuel is shut off, the motor will still keep cranking because the wheels are turning the engine...
Correct me if I am wrong...
Old Dec 19, 2002 | 06:20 AM
Russ713's Avatar
dAng!
Default Re: bent valves at track! (Haunt)
you're not wrong. that's what happened to mine last month. i have pics in my sig.
Old Dec 19, 2002 | 07:31 AM
Q-OnE's Avatar
Default Re: bent valves at track! (Black Light)
if you're running a chipped ecu then the rev limiter wouldn't matter either.
Old Dec 19, 2002 | 07:44 AM
oz#227's Avatar
New User
Default Re: bent valves at track! (FeeL's gs-R)
Sorry to here that.
Hopefully you hadn't fully enaged 3rd, you know, like clutch out- Revs start climbing way to fast - Clutch in.
You said "it's still driveable.".........DON"T. Just towed it to get fixed. I would have towed it from the track.
BTW. Which track were you at?
Old Dec 19, 2002 | 07:46 AM
RTW DC2R's Avatar
sounds like it could have been A LOT worse...you should be able to rebuild her back to normal but I guess you wont know for sure til you get her apart.
Black Light, saw the pics, all I gotta say is GAWD DAYYYUM!!
Old Dec 19, 2002 | 07:56 AM
oz#227's Avatar
New User
Default Re: bent valves at track! (oz#227)
Here my 2 Fav's..... in order. Mostly because they're the closest.
1) Eastern Creek - Sydney. http://www.eastern-creek-raceway.com/circuit.htm
2) Wakefield Park - Goulburn. http://www.wakefieldpark.com.au/site/frameset.cfm
Wakefield's the sort of track you'd love to have in your backyard. Small, but loads of fun, and the best bit, it's nearly impossible to hit anything, like Walls...etc.
Old Dec 19, 2002 | 08:38 AM
IN VTEC's Avatar
Default Re: bent valves at track! (RTW DC2)
Definitely goes on the top 20 list of blow'd up motors.
Old Dec 19, 2002 | 09:22 AM
Big Phat R's Avatar
cheers
Check your seating position - mis-shifts (up-down) are usually caused by the driver sitting too far away from the steering wheel.
Old Dec 19, 2002 | 10:52 AM
Russ713's Avatar
dAng!
Default Re: bent valves at track! (IN VTEC)
still debating on whether or not to take that as a compliment or not.
Old Dec 19, 2002 | 12:57 PM
DC2#428's Avatar
it could have been alot worse san...you have been cursed by eastern creek raceway...nice times you were pulling though....before you did your motor, that lap was your hot lap that was for sure...
Old Dec 19, 2002 | 01:06 PM
Black R's Avatar
25 Year Member
.....hey, just look at the bright side:
portflow p&p and thinner headgasket and you're good to go. Better than new!
Old Dec 19, 2002 | 01:08 PM
N1Spec's Avatar
New User
Default Re: bent valves at track! (Black R)
wow..... damn so i am lucky ay?
if i broke a valve my engine would have been kapish??? head and block?
flat out 99
Nov 26, 2011 02:00 PM
raverx3m
May 18, 2011 11:24 PM
menkio
Jul 23, 2004 12:27 PM
smokey2.0
Dec 27, 2003 05:18 AM
Ryan C
Jul 25, 2003 10:13 AM
