B16 clutch in crx
If you have the money do it now, putting a new clutch in is not that hard but its alot harder with the engine in. I did not think a normal crx clutch fit onto a b16 trans.
[Modified by 90blackcrx, 7:29 AM 12/19/2002]
The clutch youll need will be any OEM or aftermarket performance level replacement clutch set for a 90-91 Integra. Id highly recommend replacing the clutch before you have the B16 put in, or just get a swap that already has a new clutch installed.
Just do it man, you'll be happy you did.
I just went with an ACT PP, and and OE 90 Teg disk. It holds great! I bark 3rd, when I shift hard.
Also make sure and at least replace the timing belt and water pump.
CRXherbie91
Transmission & Drivetrain
Dec 11, 2012 12:57 PM
