itr cams gsr head valve clearance question(did search)
Old Dec 18, 2002 | 08:52 PM
darrinbrewer's Avatar
Default itr cams gsr head valve clearance question(did search)
for a stock 94 gsr head.. will any year ITR cams work? what year should i buy when i get them?..then when i get my valves adjusted -should they be gsr spec or ITR spec clearances? or are they the same valve clearances?
Old Dec 18, 2002 | 09:11 PM
Flamenco-T's Avatar
Default Re: itr cams gsr head valve clearance question(did search) (darrinbrewer)
any year ITR will work...you can just use GS-R valve clearance specs...
I did
Old Dec 19, 2002 | 03:49 PM
Spankee2K's Avatar
Default Re: itr cams gsr head valve clearance question(did search) (Flamenco-T)
All DOHC VTEC B-Series Head use the same valve lash measurements for valve adjustments.
legendaryTKO
Nov 19, 2007 01:32 PM
4U2NV
Dec 22, 2003 05:05 PM
darrinbrewer
Dec 19, 2002 08:23 AM
LeftCorner
Aug 9, 2002 07:57 PM
1fastGSR
Oct 23, 2001 07:24 AM
