Will this clutch fit?
if i ordered a clutch kit from exedy for a 92-93 integra, would it fit my 91 b16? i know they changed spline diameter in 92 so the disk wont work but would everything else work? i think im just going to order a 91 integra disk and run the exedy pressure plate and the rest of the stuff.....any ideas?
also would a 92-93 inegra disk fit a 00 si? if it did i have a freind who will swap me disks for a LS disk he already has.....
i know its a wierd question but i really need to know because i have to install it this friday or saturday. please someone help....
me
me
The disk you have will not work on your 91 B16. Also the throw out bearing will not work. Only the pilot bearing will.
Yes the disk will fit the new Si engine.
You can check if the LS disk will work on your engine, I'm not too sure what year your friend has.
I had the same thing happen to me, and ended up buying a new OE 90 Teg disk, and t/o bearing.
[Modified by REDBARON, 3:45 PM 12/19/2002]
im pretty sure when i did my swap i ordered a 90-93 teg 6 puck act kit and it worked fine. everything worked. it all depends on what tranny u have! y1, s1 etc etc
