My accord squeals!
Old Dec 18, 2002 | 05:40 PM
jrm86's Avatar
Default My accord squeals!
My 1999 Accord has just started squealing (actually seems to be a high pitched scraping noise directly related to speed) when I am going down the road. It seems to be coming from the right rear and is definitely from rotation. It seems to start after hitting a bump (but not always) or after turning. The faster I go the higher the pitch. I have not had the time to deal with it other than taking a quick look for anything obvious. It is parked right now until I get back in town and get it fixed. Sound lik anything obvious? Thanks
Old Dec 18, 2002 | 05:48 PM
Desslok's Avatar
Default Re: My accord squeals! (jrm86)
Pull the wheel and check the brakes.
Old Dec 18, 2002 | 05:54 PM
jrm86's Avatar
Default Re: My accord squeals! (sp)
That is sort of what I suspected. It only has 30K and it does it whether I am breaking or accelerating. I will do that when I get home. thanks
Old Dec 18, 2002 | 08:05 PM
ratherbewalking's Avatar
check for one of these!
Old Dec 18, 2002 | 08:50 PM
Alias's Avatar
Default Re: My accord squeals! (ratherbewalking)
lol at pic. Back to the topic. Check your brake pads, and calipers.
Old Dec 19, 2002 | 10:34 AM
RotaryBzzz's Avatar
It only has 30K
that sounds about right for a set of pads for some ppl. You've hit the squeal indicators...i've seen it before where they ALWAYS squeal all the time, not just when braking.
You happen to have a set of pads that decided to squeal almost all the time. If the pads still looked good once you pulled the wheels (or your about to trade the car in - ha), you could use a needle-nose plier to just bend the metal squeal bracket back slightly to kill the noise temporarily.
......:::::.. . ..... .. Sooo-wee- SOOOOOOO-WEEEEEE
Old Dec 19, 2002 | 02:12 PM
Ryu's Avatar
Ryu
Default Re: My accord squeals! (RotaryBzzz)
check the tension of your belts on your crank to the a/c and the powersteering, i had that horrible noise from the belts losing tension after my h22a settled in...
hahah just noticed right rear
but check anyways lol
[Modified by Ryu, 9:13 AM 12/20/2002]
Old Dec 20, 2002 | 07:25 AM
Bishop Don Shizzle's Avatar
Oh yeah I forgot I can edit my own title! Yay!
Default Re: My accord squeals! (Ryu)
It is definetley your brake pads. I bought my 99 Accord used and just a few months later there was this shrill squeaking noise coming from the rear of the car. Turned out my brak pads were worn down to practically nothing. Apparently the newer Hondas will let you know when your brake pads are worn out.
Old Dec 20, 2002 | 11:47 AM
jrm86's Avatar
Thanks for all the advice. I will check the brakes when I get home. That is what I originally that, but I was thrown off by the fact that it was scraping without the brakes being applied.
cindyannt
Suspension & Brakes
Jun 16, 2017 03:24 PM
elad68
Nov 21, 2009 04:20 AM
RyanAwesome
Mar 13, 2008 02:45 PM
Param
Jul 23, 2003 08:21 PM
Charlie Moua
Jun 30, 2003 02:44 PM
