HELP!! need everyone's opinion. This is my set-up...
all-motor
93 civic dx coupe, 96 JDM ITR block, SI head, Skunk2 intake manifold, Skunk2 ECU, Skunk2 valvetrain, skunk2 full exhaust, aem cam gears, JDM DC 4-1 header, 2.5 carsound cat, VAFC, RC 310 injectors, skunk2 stage 2 cams... GSR throttle body, GSR AEM cold air intake...
is the gsr throttle body and gsr aem cold air intake hurting me?? im hitting 187hp and 125tq.. should i replace them?? i want to hit +190 whp... what do i need to do? allmotor only.. not gonna open up the block.... thanks..
all-motor
well set up is good but I think a bigger TB and mabe a standaloe ECU would aid u better or get a thinner head gasket and keep old set up that would put u in the 190's
if you are running the skunk2 intake manifold, isn't that almost the same design as itr? so how are you running a gsr CAI on a skunk2 intake manifold? and also what compression are you running? stock itr pistons or aftermarket?
Do some more research your parts are not matching up correctly! I dont think u know what u are getting into!!!
skunk 2 intake? why not an ITR they are cheaper I thought they were just for GSR heads. Also those rc's are way to big I know guy's running 6lbs of boost on stock injectors that was a waste of money.
Exactly!! A stock ITR can get those numbers with just a good IHE, and by good I mean well matched. You keep throwing money at it but have a few restrictive parts. Research and you will hit 190 easily.
190 is not as easy as you guys think. a lot of the money will be spent tuning on the dyno. I don't think anyone has claimed 190 whp by just bolting a ihe setup on. i have full ihe and vafc and hit 169. with fpr fuel rail, smaller wheels I should see 175 and a fat midrange. Many of the people hitting those high numbers on a small list of mods have also done other things. Removed ps, removed ac, etc.
i agree, 180 is not too hard with IHE and few minor things, but 190 with that setup is VERY hard close to impossible without pistons or cams.
180s are attainable with just IHE:
http://members.aol.com/serverlists/i...mtbrand=AOL_US
A little tuning will get to upper 180s or 190. Someone here made 188 with just the basics and a Mugen ecu. And I do agree that it will take money to get it tuned properly.
If he tunes what he has properly and replaces a few restrictive parts he can be at 190.
stock JDM ITR pistons, head milled 20k...
I had GSR throttle body and GSR AEM cold air on it because I originally had a b18c1 but then valve hit pistons and can u say? "bye bye to head and block."
now im back with type r... might consider the AEM V2 when we see reviews.. are the 68mm Ericks too big for my set up??? thanks for your responses...
get a 68mm t-body and aport match yoru intake mani and youll brake 190 with zero tuning. if thats your goal, tehn your there. btw, why are you running 310s on that setup? your drowning the poor motor!
sleepycivix
Dec 18, 2002 04:53 PM
