Help with Throttle Body Gasket!
I am in need of a throttle body gasket for my teg, I have a GS-R head with a Spoon throttle body and Skunk manifold. I have the gasket for a GS-R, but it has a piece missing for the fast idle control valve, which is not on the Spoon throttle body. Now I would just go to Acura, and get one for the Type R, but there is no Acura dealership around here, so I would have to ride out to Orlando, which is about an hour and a half away. There is, however, a Honda dealership right around the corner from me. Does anybody know if there is a Honda gasket I could use? Please help me so I can save a trip.
-Thanks
-Thanks
all honda dealerships in canada can get all OEm acura products here in canada.... Dont think it should be different in the states
the Spoon TB should have came with a gasket if you bought it brand new. mine did..
if not then try Len aka iloveracing on the board. He can get OEM parts pretty cheap for you
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
unless it's immediately necessary, you can always go to http://www.acuraautomotiveparts.net
I got my Spoon throttle body used. I am currently using the GS-R gasket, but it is leaking because it doesn't have the fast idle control valve and it idles up and down between 1200-2200 when i come to a stop. Any ideas on Honda throttle bodies? Does the 99-00 Si have fast idle control valve? What about older Del Sol Vtec's?
Peter Langly
Jun 18, 2004 03:19 PM
