Do you run your coolant lines on your turbo???
Old Dec 18, 2002 | 01:40 PM
DIY_Racing's Avatar
Default Do you run your coolant lines on your turbo???
Ok, i have a t3/t4 garrett turbo.. it has two holes for the coolant..
Question is do you guys just block those off or do you actually run a coolant source to them? and if you do run a coolant source, from where and how?? The car is a 92 integra.
Thanks for all the info..
Old Dec 18, 2002 | 01:41 PM
ScrapinSi's Avatar
Default Re: Do you run your coolant lines on your turbo??? (DIY_Racing)
i've heard that you dont HAVE to run them, but if you do, a trick for most cars is just to use the lines that normally run through your throttle body for the supply & return...
Old Dec 18, 2002 | 01:52 PM
rca90gsx's Avatar
A ton of the eclipse guys now are not running the coolant lines, unless it's a BB center cartridge. Most have been running them for over a year with no problem.
Hope this helps....
Richie
Old Dec 18, 2002 | 02:57 PM
johnisenglish's Avatar
If you have it, run it! Your turbo will thank you for it, as it helps with cooling (obviously) and longevity. I'm putting it in line, in between the block and throttle body
Old Dec 18, 2002 | 03:31 PM
rjardy's Avatar
Default Re: Do you run your coolant lines on your turbo??? (johnisenglish)
You would be silly not to run it if your turbo has the option.
Rob
Old Dec 18, 2002 | 09:16 PM
b18cya's Avatar
Default Re: Do you run your coolant lines on your turbo??? (rjardy)
which companies sell water make cooled t3/4's? are all garret t3/4's water cooled?
Old Dec 18, 2002 | 09:25 PM
V-SPEC 1's Avatar
Default Re: Do you run your coolant lines on your turbo??? (b18cya)
http://www.cheapturbo.com ask for Ken.
Soccerking3000
Mar 1, 2004 08:28 AM
nekkedR
Jan 14, 2004 01:19 PM
You_Get_Vapors
May 4, 2003 06:17 PM
