Stripped screw in door handle.. how do i get out?!?!?
Old Dec 18, 2002 | 11:38 AM
done's Avatar
Default Stripped screw in door handle.. how do i get out?!?!?
like the party ou grab to close your door. The screw is stripped some how.. how do i get it out?
Old Dec 18, 2002 | 11:42 AM
sackdz's Avatar
Default Re: Stripped screw in door handle.. how do i get out?!?!? (Jordo)
Take out the other one, take out the plastic one, pull the door apart at the bottom, pull up like normal to remove the panel and turn the screw while doing it.
[Modified by sackdz, 3:42 PM 12/18/2002]
done's Avatar
Default Re: Stripped screw in door handle.. how do i get out?!?!? (sackdz)
ill give that a try. before i get the pilers after its ***
Old Dec 18, 2002 | 11:43 AM
hungsteR's Avatar
If worse comes to worse you can use a drill and a small drill bit to drill completely through the screw. Be careful though, you don't want to screw up anything else.
Old Dec 18, 2002 | 11:45 AM
AssPenny's Avatar
Default Re: Stripped screw in door handle.. how do i get out?!?!? (hungsteR)
The Smoke Wrench is the anwser to all your problems
bbhockey19
Jan 24, 2007 09:29 AM
todd.ludwig
May 1, 2006 02:27 AM
VietFoo
Mar 9, 2004 09:43 AM
NtegraRacR05
Sep 15, 2003 06:57 PM
PainfulTeg
Aug 3, 2002 05:30 PM
