nitrous experts... what kind of setup shoudl i use with turbo?
Old Dec 18, 2002 | 11:00 AM
Boostless97Lude
Guest
Posts: n/a
Default nitrous experts... what kind of setup shoudl i use with turbo?
any suggestions?
Old Dec 18, 2002 | 11:32 AM
kyle h.'s Avatar
Default Re: nitrous experts... what kind of setup shoudl i use with turbo? (Boosted97Lude)
Holley NOS Wet system.
1. its common fact that its better to run wet with turbo.
2. Holley NOS has been around for so long.
3. NOS is easy to get parts for when u need/break them.
4. It will be cheaper than a fogger system.
5. you're local parts store should beable to order the **** you need next day, free shipping.
Old Dec 18, 2002 | 11:34 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: nitrous experts... what kind of setup shoudl i use with turbo? (kyle h.)
single fogger, or direct port..... plus, there have been a lot of problems with NOS solenoids going out on people
Old Dec 18, 2002 | 11:48 AM
flip1199's Avatar
nx express. Direct port
Old Dec 18, 2002 | 11:50 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: nitrous experts... what kind of setup shoudl i use with turbo? (flip1199)
the one with the fuel/nitrous rails? i do like that design
Old Dec 18, 2002 | 12:24 PM
laughinxxx's Avatar
New User
any suggestions?
First off why do you want to run nitrous? You have a boost controller right?
Secondly, direct port will be best but any wet kit will work. NOS noids aren't bad, but don't use powershots. Use larger ones, they come with teflon seals instead of the rubber crap they put in import kits. Thirdly, IM me for some ideas on how you're going to want to tap your intake manifold. It is a bitch, but there are ways to make it much easier than if you do it the traditional way. you can even keep your intake mani bolted up to the head.
Old Dec 18, 2002 | 12:39 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: nitrous experts... what kind of setup shoudl i use with turbo? (laughinxxx)
i was just wanting to maybe put some nitrous on it to improve my 1/4 mile time, and something to make some more impressive numbers on the dyno, and something to make everyone "OMG, WTF is this guy thinking!?!?!" when i go to shows. plus, when i run higher boost, it'd be good to kinda keep the charge temps down.
Old Dec 18, 2002 | 12:47 PM
laughinxxx's Avatar
New User
What intake manifold are you running?
Old Dec 18, 2002 | 01:10 PM
Boostless97Lude
Guest
Posts: n/a
currently stock, but i had a Venom, but it didn't fit right, so i am thinking i am going to use a skunk2 when they come out... or maybe keep the stock one and have it ported out, that way i could use the plate system
Old Dec 18, 2002 | 02:04 PM
rjr162's Avatar
NX intercooler fogger kit. it costs around $400 or less, and works great. Granted it's not injected into the engine, but the gains are still there.
And, depending on your setup, some of the "overspray" will get sucked into the intake anyhow.. depending on where the intake is located. The kit dropped our times by over a second. (13.9's or so into the high 12's)
Old Dec 18, 2002 | 02:30 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: nitrous experts... what kind of setup shoudl i use with turbo? (rjr162)
do you have to mount that thing on the front of the intercooler, or can it be mounted on the backside?? just curious b/c i don't like the way they look
Old Dec 18, 2002 | 02:47 PM
ViZ's Avatar
ViZ
you have to mount it on thr front otherwise its not as effective.. you can turn the solidoids up so they dont stick out like that
Old Dec 18, 2002 | 04:00 PM
laughinxxx's Avatar
New User
The NOS plate kits aren't in production, so a call to NOS would be in order for you to get that.
Old Dec 18, 2002 | 04:05 PM
kyle h.'s Avatar
NOS soleniods go out because people dont use purge kits. the no2 sitting in the line rots the plunger inside the soleniod
Old Dec 18, 2002 | 04:29 PM
laughinxxx's Avatar
New User
Nope, close though. The 1000 psi from the nitrous deforms the seals, which causes a nipple on the seal. This nipple blocks part of the nitrous flow, which causes you to run excessively rich when you spray.
Old Dec 18, 2002 | 04:32 PM
Boostless97Lude
Guest
Posts: n/a
ok laughinxxx, you asked what kind of manifold i had... but i told you, but never got a response regading what kind of manifold i had. were you asking for a reason, or were you just curious?
Old Dec 18, 2002 | 05:34 PM
BoostedH23a1's Avatar
because nos used to make (maybe still does) a flapper valve kit for our intake manifolds. they replace your secondaries and its kinda like direct port just none of the drilling bullshit..
Old Dec 18, 2002 | 08:48 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: nitrous experts... what kind of setup shoudl i use with turbo? (BoostedH23a1)
yeah, that's what i thought he was getting at too, but then he told me they weren't in production i'm so confused now...
Old Dec 18, 2002 | 09:41 PM
rjr162's Avatar
i know i've seen one recently for the B16... but I guess that doesn't help too much lol
Old Dec 19, 2002 | 06:27 AM
Boostless97Lude
Guest
Posts: n/a
seen what for a B16... a plate system?? i think you were mistake, the B16 doens't have the right knod of intake manifold
Old Dec 19, 2002 | 07:08 AM
that was probably the B18.. call nos..
Old Dec 19, 2002 | 07:55 AM
laughinxxx's Avatar
New User
If you are using the stock manifold you can tap the middle piece that holds the butterfly valves. Use nylon line instead of hardlines and you'll be good to go.
Old Dec 19, 2002 | 08:00 AM
Boostless97Lude
Guest
Posts: n/a
is that what you did, or have done to other peoples? do you have an pics? and your "from the backside" title, does it refer to your nozzles being in the back?
Old Dec 19, 2002 | 08:14 AM
laughinxxx's Avatar
New User
I've seen it done, but I haven't gotten a chance to do it on my mani yet. A new manifold goes for about $500 on the site I checked, so I'll have to put it off until someone wants to trade mani's with me. Haha, no, my title refers to me asking for "From the darkside" and getting owned by the admin.
Old Dec 19, 2002 | 08:27 AM
Boostless97Lude
Guest
Posts: n/a
ok... what about brand names? which do you prefer, NOS, or NX?
