AF guage install
Old Dec 18, 2002 | 05:27 AM
mattsy93vtec's Avatar
Default AF guage install
I have searched to the end's of the earth for this... but I have tried to install an AF guage, and I have no found any info as to where to tap into. I have a '93 VTEC. I first tried the ECU but could not find the correct wire (boy what a waste of ripping up my whole interior), then I tried tapping off the O2, but did feel like going underneath my car, is there a place I can tap it before it hits the firewall or is there somewhere else I can tap it?
- matt, thanks in advance.
Old Dec 18, 2002 | 06:08 AM
rjr162's Avatar
Default Re: AF guage install (mattsy93vtec)
just tag it off the ECU.. it's really not that hard. use a helms manual, and to dbl check you got the right one, strip back the coating and use a multi-meter on it... when the car's on it should bounce between .4 and .6 +/- some, and when you floor it it should go up alot more.. like .8 volts... and when you let off, it should drop to .2 or so.
Old Dec 18, 2002 | 07:13 AM
BoostedH23a1's Avatar
Default Re: AF guage install (rjr162)
i know u dont wanna go under the car but if u dont wanna get it off the ecu get it off the the O2 harness. shoot for ecu
Old Dec 18, 2002 | 11:04 AM
Default Re: AF guage install (BoostedH23a1)
Hmmm... I don't know if it's just me or not. I'm using the Honda service manual, and it really isn't clear to me as to which one it is (or the color). Can anyone look it up for me? All I need is the pin location and the color wire. And can't I just jam the wire in the plug so I dont have to cut the harness? I really dont want to be cutting, it's really tight as it is down there, and my interior will never go back together the same way as it is. Hehe.
- M
Old Dec 18, 2002 | 11:13 AM
Boostless97Lude
Guest
Posts: n/a
one of the black wires off the first O2 sensor will be fine, if it doens't work, trying splicing into a white one... i can't remember which wire i used, but i've got a wideband now, so i guess it don't matter much to me... HTH, probably doesn't, but o well
EkChuck
Engine Management and Tuning
Nov 24, 2012 03:24 PM
heel_touge
May 14, 2009 09:48 AM
zexifiedlude
Sep 5, 2006 05:38 AM
miksew
Sep 10, 2003 05:49 PM
