? about installing 95 teg airbags in a 98 teg
Old Dec 18, 2002 | 12:06 AM
JDiMageDC2's Avatar
Default ? about installing 95 teg airbags in a 98 teg
I am selling a full set of 95 airbags, srs module, and complete wiring harness. What type of minor modifications need to be made to make this 95 SRS system work in a 98 Teg. Ive heard that one plug has to be changed out but do not know the specifics. If anyone can tell me what needs to be done to make this work please help me out. Ive got a buyer if I can explain to him how to do it. Thanks.
Old Dec 18, 2002 | 06:34 AM
b18bvtec4drteg's Avatar
Default Re: ? about installing 95 teg airbags in a 98 teg (GSRTUNR)
I would like to know this as well.. I have heard you must change the front cover to make that work.
Old Dec 23, 2002 | 12:28 AM
digitalspice's Avatar
Banned
Default Re: ? about installing 95 teg airbags in a 98 teg (b18bvtec4drteg)
Your in luck ive been researching this topic. Heres some info,94-95 integra airbags will only fit those years integras as they are OBD I, they will also fit 92-95 civics. The reason being is the cable reel and plugs on both the reel and the airbag itself changed on the 96 and up integras. You are right on changing the plug, You could either change the plug on the airbag side, Which I would NOT recommend, Might cause it to deploy accidently (OUCH!). Or you could change the plug on the cable reel side, (Much better) The only problem I would see with doing that is the wires going into the plug harness are both the same color, So how do u tell which one is which? IE(negative or positive) and what would happen if you wired it up wrong and then plugged in back in? Would just the SRS light come on or would it cause it deploy? Im still trying to find the answers to those questions but I hope some of the info I gave you is helpful.
Old Jan 27, 2004 | 02:09 PM
terriblewind's Avatar
Default Re: ? about installing 95 teg airbags in a 98 teg (digitalspice)
Hello,
Do you know where the srs control module goes in an 98 integra?
I am trying to install the airbags and the control module is holding me up since I don't know where it should be installed?
Also is there a sequence that everything must be installed?
Any help would be greatly appreciated.
Thanks you. Please help.
Old Jan 27, 2004 | 02:29 PM
Erik_Pb_Foot's Avatar
New User
Default Re: ? about installing 95 teg airbags in a 98 teg (terriblewind)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by terriblewind &raquo;</TD></TR><TR><TD CLASS="quote">Hello,
right in the middle where the floorboard/firewall meet behind the dash... behind the radio, if you will... follow the yellow wires.. they ground right there too... just pull the carpet up a little... can't miss it.
Old Jan 27, 2004 | 02:30 PM
New User
Default Re: ? about installing 95 teg airbags in a 98 teg (Erik_Pb_Foot)
that's where it is in a 96, so i'm assuming 96-98 would be, at the very least, the same.... both obd2a
Old Jan 28, 2004 | 11:25 AM
Thank you so much you're cool
Old Jan 28, 2004 | 11:26 AM
Thanks a bunch, you guys are cool
ImXposed
Aug 25, 2005 06:29 PM
MenaceL.A.671
Nov 15, 2004 10:21 PM
lsvtec101
Nov 17, 2003 06:31 AM
MIKEGSR95
Oct 17, 2001 09:18 PM
