integra rims with 55 mm hub hole
Old Dec 17, 2002 | 08:22 PM
JSR3STS's Avatar
Default integra rims with 55 mm hub hole
hey ive been looking at some 15 x 7 rims with a 35mm offset and 55mm hub hole, will they fit my car??
95 integra gs
Old Dec 17, 2002 | 08:45 PM
Weston's Avatar
Default Re: integra rims with 55 mm hub hole (Sleepin 95 Tegra)
95 integra gs
I'm not sure what size the stock "hub hole" is, but if the new rims are bigger, then you can just get some hub centric rings. A tire place should have them. The 35mm offset and 7" width will make the tires stick out a bit. I'm running a 40mm offset and 15x6.5 rim (205 Azenis tire) and they are out just far enough so that they'd rub if I were to lower the car enough. Yours will stick out further than mine, so it's a no-go if you want to lower it much. I'm thinking a 0.75" drop will be fine for me, but I'd be afraid to go any lower.
j_mee_5
Jan 30, 2010 02:01 PM
Sturg
Sep 9, 2009 04:30 PM
stevescivic
Aug 14, 2005 05:54 PM
nsxtasy
Apr 5, 2005 06:15 PM
JSR3STS
Jul 21, 2002 08:21 PM
