Point me in the direction of Si-R Front/rear seats
Old Dec 17, 2002 | 07:38 PM
Ef Whore's Avatar
Default Point me in the direction of Si-R Front/rear seats
Lke it says, looking for website that has the Si-R front and rear seats, preferably leather but cloth is fine. Also, will these bolt right into to a 91 si hatch? Damn i'm a noob....
Old Dec 17, 2002 | 07:50 PM
EF-9SiR's Avatar
Default Re: Point me in the direction of Si-R Front/rear seats (Ef *****)
i have jdm EF9 rear and front seats...both are cloth with the same pattern...black with red stitching and a little bit of white...i guess since the fronts are cloth they arent Si-R, which i believe are leather and cloth. i found them on ebay. you can try there. the only annoying thing about the jdm front seats is the brackets are reversed....the us driverside/jdm pass. side slides forward w/ the spring when u hit the lever. so u have to readjust everytime u slide the seat forward for rear access. and the us pass./jdm driver side only flips down when u hit the lever. paid ~350 for rears. perfect condition ~275 for front, small hole reg wear and tear. The seller on ebay is jd177spec. its a shopped called autosonic out here in s. california. good luck finding the seats.
Old Dec 17, 2002 | 08:17 PM
Gump's Avatar
Default Re: Point me in the direction of Si-R Front/rear seats (EF-9SiR)
Ef9 front and rear seats are all cloth, while the EF8 are leather and cloth, the fronts will not bolt up to a USDM car, the brackets are closer together, you will have to drill to make them fit
Old Dec 17, 2002 | 08:26 PM
Ef Whore's Avatar
Default Re: Point me in the direction of Si-R Front/rear seats (Gump)
how difficult is the drilling and adapting to make them fit--i have the mechanical knowhow i just want to know what im getting into if i can even find them---and can i put on the si brackets to make them slide/lock correctly?
Old Dec 17, 2002 | 08:30 PM
ViperRedCRX's Avatar
while you guys are at it, point me to a sir hood
Old Dec 17, 2002 | 08:32 PM
Ef Whore's Avatar
Default Re: Point me in the direction of Si-R Front/rear seats (CRX-T)
http://www.jdmhondaparts.com katman the internet superstar will hook u up.
Old Dec 17, 2002 | 08:37 PM
Gump's Avatar
don't know how difficult it is, I didn't have to do it to my car, it came with it
Old Dec 17, 2002 | 08:59 PM
EF-9SiR's Avatar
no, the seats fit....i got seats from an 88 jdm ef9... the us pass. side fit in perfectly...but the us driver seat... all but one bolt lined up correctly. oh, i have an 88 civic hatch.
Old Dec 17, 2002 | 09:04 PM
Ef Whore's Avatar
EF-9Sir, where did u find your seats, lemme know
Old Dec 17, 2002 | 09:37 PM
EF-9SiR's Avatar
i did tell you...about 7 posts up...ebay. and i gave u the sellername.
Old Dec 17, 2002 | 09:42 PM
Gump's Avatar
How do they fit? I have a real EF9, and a 90 USDM Civic Si, and I know for a FACT that they are not the same, the brackets are totally different
Old Dec 17, 2002 | 09:45 PM
EF-9SiR's Avatar
i have no idea how they fit, maybe because i have an 88, and the seats came out of an 88, but like i said only one bolt doesnt line up right....88 brackets are different from 89-91...i just know my seats fit.
nikebot23
Jul 15, 2015 04:26 PM
-jacob-
Oct 9, 2008 04:49 PM
93civls
Mar 8, 2004 08:45 PM
