Quick question: I need the compression ratio of my d16z6!
Old Dec 17, 2002 | 06:09 PM
Mark's Avatar
*Bounty Hunter*
Default Quick question: I need the compression ratio of my d16z6!
Id also like the compression ratio of a turbo'd d16...My father says turbo'd setups have higher comp. ration than suped N/A cars...plz help!
Edit: Stock that is! Also...anyone dyno their d16z6? Wouldnt mind knowing that either
[Modified by 94BlackCivicEX, 3:13 AM 12/18/2002]
Old Dec 17, 2002 | 06:15 PM
13HYBRID20's Avatar
Default Re: Quick question: I need the compression ratio of my d16z6! (94BlackCivicEX)
9.2 to 1 there are two compression ratios this is the normal c/r what you are talking about I think is called static c/r it is based on how much air you put in. You could figure it with the amount of boost you are running
Old Dec 17, 2002 | 06:19 PM
Kamin's Avatar
ok lets go ahead and tell dad that the static compression ratio dosent change, ever. (unless you do somthing to change it)
and LOWER compression is better for turbo
HIGHER compression is better for NA
as for dyno of the z6, about 100hp to the wheels.
EG6 Love
Feb 16, 2008 03:35 PM
zman
May 10, 2004 09:24 PM
xXx Justin xXx
May 15, 2003 09:42 PM
Mike_C
Mar 20, 2003 07:15 PM
