small oil leak..
Recently purchased a 94 GSR that I knew had a small oil leak.. I don't see the oil dripping from the car, however every other day or two I do see a small puddle of oil under where my car is parked.. I know oil leaks are hard to track but... my compression #'s came out flawless, if that helps narrow anything out..
could it be the oil pan gasket? the car does have a lot of miles.
Oil drain plug could possibly not tightened properly.
Torque to 33lbs/tq
Also oil gasket is probably old.
Change your oil now with a new gasket and tighten the bolt properly.
This is what I had in mind.
HTH
Torque to 33lbs/tq
HTH
