8 flashes on the computer
On my way home this eveing i was running it kinda hard and then the check engine light came on i pulled the panel and it was falshing 8 times and 4 times and it was runnign real rough i reset the computer and it threw just a 8 flashes when you start the car up up after restarting the car it runs fine utill you give it alot of throtle then it comes and the motor runs bad. what could this be and where should i start to look for the problem.
I am running a ZC DOHC in my car
thanks chris
thanks chris
bump
nobody had this problem, i have be fidling with car some and it seams to run ok until the car warms up, it still has the code but doe snot run bad, until it gets hot.
help
help
Vagitarian
Jul 14, 2012 05:06 PM
