Longblock H22 specific/Swap Info.
Old Dec 17, 2002 | 11:07 AM
ForcedAccord's Avatar
Texas B*tch!
Default Longblock H22 specific/Swap Info.
Posted this in the Accord forum as well, but not quite as much activity.
Alright I was just browsing through some JDM-USDM engine sites and I came across where you can buy just the H22a "longblock."
<u>H22a Longblock Includes:</u>
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Distributor
<u>Full H22a Swap Includes:</u>
- Motor
- Hydrolic Tranny
- ECU (P13)
- Axles
- Shifter Cables
- Shifter Assembly
- Stock Motor Mounts
- Engine Harness
- All Sensors Needed
- LSD Tranny (Optional +$300)
From what I can get out of comparing, all that is lacking with the longblock is the ECU, axles, motor mounts, harness, and transmission.
I know the stock Accord axles should work, along with the transmission. Then I can just pick up an ECU for around $250 and be on my way. Also someone mentioned the prelude mount and an engine harness. What would I be looking at for those items?
For someone wanting a swap soon, would buying the longblock using the stock axles/transmission be fine until funds allowed for the other stuff?
Or are there a lot of other variables that I am not considering?
Thanks in advance.
Old Dec 17, 2002 | 12:49 PM
Texas B*tch!
Default Re: Longblock H22 specific/Swap Info. (ForcedAccord)
Old Dec 17, 2002 | 12:58 PM
Boostless97Lude
Guest
Posts: n/a
you've actually already answered your own question.... some of the stock accord moutns will work, i think, and the motor will have a few mounts on it i'm fairly sure, but until you actually have everything, it's hard to say what you will and won't need. i am sorry i can't provide more info, but my car came with an H22 from Honda, so i have never researched a swap
Old Dec 17, 2002 | 10:45 PM
Texas B*tch!
Default Re: Longblock H22 specific/Swap Info. (Boosted97Lude)
Haha thanks for taking a stab at it, any others?
Old Dec 17, 2002 | 10:54 PM
KTeller8's Avatar
i did the 96 h22 in the 96 accord
you need the longblock and driver side motor mount..
the ex wireing harness will work, you just have to splice a sensor or two and lengthen a few
axels will be A-Ok
also all i got was the longblock.. then i picked up the accord tranny just cause...
Old Dec 17, 2002 | 11:08 PM
Texas B*tch!
Default Re: Longblock H22 specific/Swap Info. (KTeller8)
Tehehe go to sleep man
I emailed you for those prices.
soundFX
Jul 13, 2006 11:22 PM
Jerry31
Jul 4, 2004 11:32 AM
Doug Pollom
May 4, 2004 07:36 AM
ForcedAccord
Dec 23, 2002 04:33 PM
ForcedAccord
Dec 17, 2002 12:48 PM
