strange noise at idle
Old Dec 17, 2002 | 10:44 AM
vrrodri's Avatar
Default strange noise at idle
My 93 DX HB makes a weird noise at idle, sort of coming from the valvetrain(MAYBE), I can only hear it well when inside the car but it definitely comes from the engine. It is a dry tone kind of noise, low pitch and constant, tends to dissipate above 1200 rpms.
At first I thought that I needed to adjust the valves, I did but the noise remains the same.
I also changed the water pump, and adjusted ignition timing, changed the plugs, oil, coolant. Still the noise remains.
Any ideas?????
Sometimes I get a bad idle, the idle speed drops and stays that way, does not do it all the time.
Thanks
Old Dec 17, 2002 | 10:47 AM
Spade's Avatar
Default Re: strange noise at idle (vrrodri)
Alternator?
Old Dec 17, 2002 | 12:10 PM
vrrodri's Avatar
Default Re: strange noise at idle (Spade)
hmmmm, I would think that the alt would make a high pitvh noise if bad, but it is worth a look. The car runs great otherwise, it accelerates fine.
Thanks
Old Dec 17, 2002 | 12:19 PM
AbaZ's Avatar
Start taking your belts off, and see if its one of those, each time you take a belt off start it up..
Also does the noise go away or change when you push the clutch in? its very possible it could be a throw out bearing.
Jeff
Old Dec 18, 2002 | 03:57 AM
vrrodri's Avatar
Default Re: strange noise at idle (AbaZ)
Thanks, but I do not think it is the release bearing. The car makes the noise with the tranny at neutral and there is no change whatsoever if I push the clutch pedal and select first gear.
It seems to come from the engine itself. Have you ever heard the noise from a bad water pump bearing? Sounds a bit like a diesel, this is a similar noise but not as loud as a diesel noise, and is best noticed sitting inside the car at idle.
Old Dec 18, 2002 | 11:39 AM
deepnite's Avatar
could be a belt with a bad spot on part of it..id get a belt dressing and wet down each belt one at a time and find out which one it is thru deduction..if the sound is still there *I have no idea*
Old Dec 18, 2002 | 11:49 AM
vrrodri's Avatar
Default Re: strange noise at idle (deepnite)
I replaced both belts when I replaced the timing belt recently.
The noise was there before I replaced all belts and remains the same.
I do not think it is the belts, it is an engine kind of noise. hard to pinpoint.
whatmeow
Honda Civic (2006 - 2015)
Nov 28, 2018 03:31 PM
Shermanef9
Jul 26, 2008 11:29 PM
Gump
Dec 6, 2003 02:48 PM
MaxPowerIntegra
Jul 29, 2001 01:00 PM
