IMPORTANT weight of Aftermarket rods for h22a. (PLEASE READ)
Old Dec 16, 2002 | 11:41 PM
HotWheelz's Avatar
Default IMPORTANT weight of Aftermarket rods for h22a. (PLEASE READ)
I'd like to know some specs on aftermarket rods if possible. regarding their weight in Grams for the following rods...
- Crower IBEAM
- JUN
- Eagle HSP
- Probe Industries
- Carrilo
- Pauter Machine
- OEM obd1
- OEM obd2
standard h22a rods, stock journal and big end and small end... trying to see if there is that many differences. between them all.
if you have added rods please add them and the weight you mesure or got for that rod... thanx!!!
Old Dec 17, 2002 | 08:40 AM
96SR-V's Avatar
Default Re: IMPORTANT weight of Aftermarket rods for h22a. (HotWheelz-turboh22dx)
Your setup looks very similar to mine..If I were u I wouldn't bother w rods....If I did it all over again I would have kept my stock rods and valves..I went w ESP eagles and crower SS valves. I think stock valves flow the best and the rods....well I could have made the types pistons fit on mine w a little work from the machine shop.... I'd save the money if I were u.
Old Dec 17, 2002 | 08:43 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: IMPORTANT weight of Aftermarket rods for h22a. (96SR-V)
ask Viren, his HT name is b18bturbo, he is the one i bought my rods from, and he even balanced them for me, i got eagles, but i am sure he will know
Old Dec 17, 2002 | 09:51 AM
aklucsarits's Avatar
New User
I don't know what the weight is, but it was recently discovered that later H22A4s (00 and 01 models at least) have rods from the factory that are both forged and visably much thinner looking in order to reduce internal rotating mass.
Andrew
Old Dec 17, 2002 | 10:00 AM
satan_srv's Avatar
Default Re: IMPORTANT weight of Aftermarket rods for h22a. (aklucsarits)
Andrew
Do they look like these? These are my F20B rods...
Old Dec 17, 2002 | 10:12 AM
New User
Default Re: IMPORTANT weight of Aftermarket rods for h22a. (satan_srv)
I can't tell from that pic. But somebody posted pics about 1 month ago of the old cast H22A Honda rods VS the "new" forged H22A Honda rods.
Do a search, n00b.
Andrew
Old Dec 17, 2002 | 11:06 AM
HotWheelz's Avatar
hahahahha (noob)
well i have the parts listed in the sig, the motor appart and waiting until march to assemble.. in the meantime i`m buying all that i can afford, once march it`s getting assembled and dropped in my ek, i have all the parts to do the swap allready... weird eh, a built h22a in an ek from a GSR coupe.. i hope it`s fast and fun.... i`d rather buy h22a aftermarket rods.. it`s not really the money that bothers me is added security if you wish.. just knowing i have something down there is better...
and well i might ITBS once i get a good header this summer.. so good strong rods for na reving is a must
if this puppy blows then sleve and turbo hell the motor will allready be partially built for it anyways..
Old Dec 17, 2002 | 12:46 PM
satan_srv's Avatar
Do a search, n00b.
Andrew
You bastard I found this thread YOU started https://honda-tech.com/zerothread?id=318422
H22a4 vs. Pauter
H22A1
Newer H22A4 rods are defitely 'thinner' and 'forged' then?
My F20B rods are of the new design as well, which I suppose is encouraging...
[Modified by satan_srv, 4:47 PM 12/17/2002]
Old Dec 17, 2002 | 03:47 PM
New User
Oh yeah, that's the one! So the left rod in the top pic is the "new" forged H22A rod, and the bottom pic shows 4 "old" H22A rods. You can see that the rod portion of the ...umm ...rod ... is narrower. And the Crank-end looks a bit less substantial.
Andrew
Old Dec 17, 2002 | 05:06 PM
HotWheelz's Avatar
aftermarket rods.. please... need weight specs in aftermarket rods....
to see if some are heavier than others ...
Old Dec 17, 2002 | 05:18 PM
satan_srv's Avatar
Interesting if you look at my F20B rods they are quite a bit different from the h22a rods...
Old Dec 18, 2002 | 03:01 PM
DarkJedi's Avatar
fyi: the bottom pic are of my old rods(off a jdm h22a), replaced them with eagle ESP rods which are definately a bit lighter than stock
Aaron.Hillman
Mar 26, 2004 12:31 PM
h22aLSD
Oct 8, 2003 07:07 AM
HotWheelz
Jan 22, 2003 08:37 PM
Toretto
Dec 8, 2002 04:03 PM
se93
Jul 6, 2002 09:45 AM
