My car dies when I hit bumps...
Old Dec 16, 2002 | 06:53 PM
DJ0820's Avatar
Default My car dies when I hit bumps...
When ever I hit a bump my car will hesitate if I'm in gear, or just die if I am in neutral or have the clutch in. Any ideas as to what the source of the problem is?
Later,
Derek
Old Dec 16, 2002 | 07:13 PM
90_Civic_Hatch's Avatar
Default Re: My car dies when I hit bumps... (DJ0820)
I had that problem. My ecu clip was loose at the time. I hit a bump and my car putted and stalled. then it wouldnt start some of the time, then i clipped it back in. So.... check your clips, check wiring inside the car and make sure everything is connected correctly. it definitely sounds like a short in the wiring. you may be throwing a code also, wich would indicate the loose wire.
Old Dec 16, 2002 | 07:51 PM
customx_'s Avatar
New User
loose ground?
Old Dec 16, 2002 | 10:43 PM
Vinceg99's Avatar
Default Re: My car dies when I hit bumps... (anti_sp00n)
I would say check all your grounds and also check your Distr.
Old Dec 17, 2002 | 04:28 AM
DJ0820's Avatar
Default Re: My car dies when I hit bumps... (Vinceg99)
Hmmm, i just installed my SMC so I don't have the cover or anything on the ECU, I just have it bolted down. My guess is that I just didnt clip the clips in there good enough. Keep the ideas coming though, in case that's not my problem.
Later,
Derek
Old Dec 17, 2002 | 05:09 AM
virginia_dude's Avatar
With the car idleing with emergency brake on check your wiring by wiggling. everything. odds are you'll find the offenting problem. Most likely a bad or loose conection on something.
Old Dec 17, 2002 | 07:02 AM
rasta420's Avatar
Default Re: My car dies when I hit bumps... (virginia_dude)
its def. an electrical problem...
check the "reluctor" wires - a clip with two wires (blue and black) running from next to the dist. to the igniter inside the dist i believe.
i had the same problem and every time these wires moved the car would cut off.
Old Dec 17, 2002 | 07:35 AM
spun Vtec's Avatar
Default Re: My car dies when I hit bumps... (rasta420)
sounds dizzy to me
Old Dec 17, 2002 | 07:51 AM
DsMWookie's Avatar
electrical problem.....
Old Dec 17, 2002 | 05:55 PM
DJ0820's Avatar
Default Re: My car dies when I hit bumps... (forward_motion_crx)
I pushed the ECU plugs in further and straightened out the wires down there and the problem seems to have went away. Thanks for the help guys I appreciate it.
Later,
Derek
civic4dizoor
Honda Civic (2001 - 2005)
Jan 19, 2012 04:01 PM
miggy23
24
Feb 21, 2011 08:37 PM
preludejayes
Aug 18, 2007 04:23 PM
v-tec maz
Apr 16, 2006 07:11 AM
boosted_hatch_216
Jun 9, 2005 09:46 PM
