Headlights get brighter as I rev???
Old Dec 16, 2002 | 06:51 PM
DJ0820's Avatar
Default Headlights get brighter as I rev???
When I rev up my engine my headlights get noticably brighter. Can anyone tell me what the source of the problem is? I have a feeling that this is what has been causing my radar detector to malfunction recently.
Later,
Derek
Old Dec 16, 2002 | 06:52 PM
ElementMotor's Avatar
Default Re: Headlights get brighter as I rev??? (DJ0820)
Is your battery dying on you or anything like that?
Old Dec 16, 2002 | 06:55 PM
BlackCRX's Avatar
Default Re: Headlights get brighter as I rev??? (Forever JDM)
try upgrading your grounding
mine did that for the longest time but after i upgraded my ground its not as noticable
Old Dec 16, 2002 | 07:02 PM
E-lude78's Avatar
Default Re: Headlights get brighter as I rev??? (BlackCRX)
maybe you alt. is about to kick the bucket
Old Dec 16, 2002 | 07:07 PM
DJ0820's Avatar
Default Re: Headlights get brighter as I rev??? (Mista B-one-seven)
my battery has died randomly in like 2 minutes a couple times in the last couple weeks...What grounds do I go about updating?
Later,
Derek
Old Dec 16, 2002 | 07:41 PM
chhuong's Avatar
if your battery has died unexpectedly like that, then i say the reason why your lights are dim and get brighter as you rev is because a diode went out in your alternator!! I'm sorry to say!!
Old Dec 16, 2002 | 09:34 PM
BlackCRX's Avatar
if your car dies while its running then its time for a new alternator
and the grounds i upgraded where the once from the battery to the head cover, chasis, and tranny
Old Dec 17, 2002 | 05:57 PM
DJ0820's Avatar
ooooooo, another neat problem! When I'm listening to the stereo and I shut my car off and take the key out, the stereo will keep playing for a good 10 seconds before it shuts off. It's neat but I have a feeling it's very bad.
Later,
Derek
Old Dec 17, 2002 | 09:57 PM
gray89si's Avatar
Do you shut your radar detector off when the car isnt running? A honda tech once told me its hard on the alternator to leave a radar detector on when it isnt running. As for the headlights being dimmer after youve revved on the motor, it seems to be a common thing, mine does that too, I have a radar detector as well.
Old Dec 17, 2002 | 10:24 PM
RCautoworks's Avatar
Default Re: Headlights get brighter as I rev??? (gray89si)
You can test your battery and your alternator to see if there both working properly. Test the battery, it should read around 13 or 14, then when you start the car it should go up. You could upgrade your grounds. My car does the same thing, everything is fine though with mine.
[Modified by 90blackcrx, 7:25 AM 12/18/2002]
Old Dec 18, 2002 | 02:06 AM
illusive's Avatar
From the sounds of it again I suggest getting your battery and alternator tested and or replaced. It seems to be a pretty common thing mine does that and I have went through all of mine when I got it. Had my alternator rebuilt, battery replaced and grounded the car better but still dims. I am not sure about this but I am thinking it might be my regulator in my alternator which regulates how much power is generated not sure though might be totally wrong on that.
Old Dec 18, 2002 | 04:32 AM
broncoman74's Avatar
From: Northwest Hills of, CT., United States of America
The battery may be old and it may not be holding a charge like it is supposed to anymore. I still agree with replacing the ground straps anyway whether there is a problem or not. The best thing to do to see where the problem lies is go to a large chain auto parts store. Most of them have a machine that checks your charging system(Alternator and Battery) and they will check it for free. If it is the battery they will install the new one for free if you buy it from them. Hope this helps!
[Modified by broncoman74, 1:35 PM 12/18/2002]
Old Dec 19, 2002 | 06:04 AM
DJ0820's Avatar
Default Re: Headlights get brighter as I rev??? (broncoman74)
up
Old Dec 19, 2002 | 06:28 AM
ProstockH22crx's Avatar
Definitely alternator. Had same problems with a previous daily driver.
Old Dec 19, 2002 | 06:47 AM
Mr Furball's Avatar
Default Re: Headlights get brighter as I rev??? (ProstockH22crx)
I have had my crx for 2 years and my alt. has not died and my headlights have been doing the same thing from the day I bought the car. I have put a swap in it and still have not had any problems. When I push on the gas a little my headlights, guage cluster, all lights in car get brighter. When car is at idle, all lights in and out are dim.
nothing to worry about.
Old Dec 19, 2002 | 08:16 AM
DJ0820's Avatar
Default Re: Headlights get brighter as I rev??? (FURBALL B-16)
But what about the radio staying on? That can't be good.
Later,
Derek
Old Dec 19, 2002 | 08:21 AM
YumVTEC's Avatar
Same thing in my EK with b18c5 swap. Pisses me off. I think the voltage regulator in my alternator must be going out. I dunno... Glad I'm not alone in this problem though.
Old Dec 19, 2002 | 09:58 AM
Hello Bart's Avatar
Default Re: Headlights get brighter as I rev??? (YumVTEC)
That happens to all the cars it is nothing I would be worried about.You do not need a new alt
Old Dec 19, 2002 | 11:38 AM
Default Re: Headlights get brighter as I rev??? (turbohatch13.0)
But then again, he says his battery dies randomly. That doesnt happen to all cars.
Old Dec 19, 2002 | 02:01 PM
DJ0820's Avatar
The radio thing isnt normal either!!!! It's neat but it's creeping me out.
Later,
Derek
Old Dec 19, 2002 | 03:26 PM
shorti's Avatar
some radios have timers on them that shut themselfs off after the key has been taken out of the ignition.....
maybe your radio does that?
Old Dec 19, 2002 | 07:40 PM
DJ0820's Avatar
Default Re: Headlights get brighter as I rev??? (shorti)
I think I know why my radio stays on now. Last weekend I installed a capacitor in my fuse box for my radar detector that I have hard wired in. I think I have the power side of the detector in the radio fuse.... I think when I pull the key out, the radio just drains the capacitor and then shuts off. Its pretty neat. If this is what is happening I just might have to do a write up on how to do this lol.
Later,
Derek
Old Dec 19, 2002 | 07:50 PM
hoya_10fintec's Avatar
mine, too!!
Old Dec 19, 2002 | 09:35 PM
ef9jdm's Avatar
Default Re: Headlights get brighter as I rev??? (hoya_10fintec)
probaby ur alternator or ur ground wires
Old Dec 19, 2002 | 10:33 PM
CdTriX's Avatar
i had that same problem..
check the tension on your belt... because the tension is too tight it over charges the alternator running everything brighter...
if you over rev you can overcharge the alternator and blow it
it happend to me.. got new alt.. installed and tensioned properly and it's fine now
my radio does random beeping after i turn the car off and take the key out... it's a sony thing
