wats the diffrence between a ef8 rad support and usdm rad support?
I don't have a pic of them.
Only the US HF model uses that piece to support the radiator, and only on one side.
That piece is used to close the hood.
The JDM one has an opening for the stock air intake on the passenger side .
You can use the US "radiator support" with the JDM front end.
All you need to do is move the latch on the hood 1/2 inch backards towards the windshield.
do u have aim? heres mine tranng84. this the jdm support http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1923185195 and this is the usdm support http://cgi.ebay.com/ebaymotors/ws/eB...tem=1874754492 i dont get wat u talking about. please give me discription
OK, let me make this simple.
You only need the JDm radiator support if you are using a JDM SiR hood.
If you cannot get a JDM radiator support, you can use the US radiator support by moving the latch under the hood backwards 1/2 inch.
The bumper support you are talking about goes INSIDE the bumper.
The US DX and SI use a heavy stamped steel bumper support.
The HF uses a lighter bumper support.
None of the US BUMPER supports work with the JDM bumper cover, which is the plastic thing you actually see and call a bumper. For the JDM bumper to work, you need the JDm bumper support which as far as I know, always comes with the bumper cover.
yea i have some 2 long metal thing inside my jdm bumper is dat it?. u said move the latch forward as in forward to the engine???
move it toward by 1/2 inches? wil it fit? do i need to cut the hole? dats all i need to do rite to make the bumper and hood fits? someone help mee!!!!!!!!!!
you might have to cut a little i dont know, but from what it seems it cant be too hard to move it 1/2 inch, if anyhting take it off and run hoodpins
How the hell are you all moving this latch back? Please explain the process in detail or pics would also be nice......
my ef9 rad support worked fine and u have to move the us support forward they are completly different the sir from non si ones us or jdm so jdm ef7 would work with a us hood and vise versa
b16_madman
15
May 27, 2004 07:28 PM
