Help ! Changing fog-light bulbs ??
I tried to get at it earlier today but was unsuccessful .... Can anyone offer me some advice ??
I'm new to the board but I like what I see so far !!
[Modified by PAULIE_D, 9:30 PM 12/16/2002]
I can loosen the screws through the access holes in the front grill but it seems next to impossible to remove the fog light from the bumper in order to get at the bulbs...... hmmmm
Oh yeah .... how come my signature isn't showing up ? I used valid html code .... also , it seems like I can't use my own avatar ?? Am I wrong ??
its the same as replacing your headlight bulb but you'll prolly have to take the whole fog light out. which means take your turn signal out and your fog out. are you tryin to change the bulb without takin the turn sig and fog out? haha if so
I figured it out .... of course you first have to remove the turn signals (only one screw per side) For the OEM fog light, there are in total, five visible screws which are seen through the access holes in the plastic grille inside the front bumper. The largest screw which is in the middle on the "inner" side of the foglight is only an adjustment screw and should not be unscrewed. There are 4 little screws that hold the housing in place... loosen these but do not remove them completely.... then jiggle the foglight housing , then take a flathead screwdriver and gently pry on the inside edge (side closest to the radiator) of the foglight housing in order to clear the plastic grille on the bumper. Once the housing is removed, you can remove the bulb and replace.
[Modified by PAULIE_D, 9:20 PM 12/17/2002]
94GSRRacer2
May 10, 2002 09:16 PM
