negative battery cable question
Old Dec 16, 2002 | 02:57 PM
crxaddikt's Avatar
Default negative battery cable question
i switched my negative battery cable, and i noticed that one end attaches to the engine block/tranny thing, and the other to the neg terminal, but also it had a metal bracket sticking out of the middle of the cable that attached to the body of the car.
the thing is, the cable i replaced it with did'nt have that center bracket coming out from the middle of the wire, and i did'nt thing it mattered, but now my battery light is on again.
so does anyone know if that middle bracket coming off the center of the negative battery cable is meant for grounding purposes?????
cause if so, you might of solved my problem, thanks
Old Dec 16, 2002 | 03:03 PM
MADEINIRAQ's Avatar
Default Re: negative battery cable question (crxaddikt)
thap part might be but not sure, make sure the cable going from the valve cover to the chassis is good.
Old Dec 16, 2002 | 03:25 PM
89civicdx's Avatar
Default Re: negative battery cable question (madeiniraq)
yes its a ground...you should ground it to the body.
DrDenby
Honda Civic (2001 - 2005)
Jul 6, 2015 07:13 AM
MarkM01
Apr 25, 2011 05:02 AM
dgerej2
Sep 9, 2009 07:31 PM
drjondurst
Mar 30, 2003 07:16 PM
