how low should i go?
Old Dec 15, 2002 | 04:25 PM
01nhbgsr's Avatar
Default how low should i go?
gettin some skunk2 coils. jw how low should i go to not mess up the camber on my stock suspension setup
Old Dec 15, 2002 | 04:26 PM
Deluzional's Avatar
Default Re: how low should i go? (01nhbgsr)
In order to avoid camber issues, you should only drop your car about 1.5 inches
Old Dec 15, 2002 | 05:34 PM
01nhbgsr's Avatar
Default Re: how low should i go? (Deluzional)
what about 2
Old Dec 15, 2002 | 05:44 PM
tegasaurus's Avatar
no.... 1.5
Anything more than 1.5 does not improve handeling unless you have well matched dampers.
Old Dec 15, 2002 | 05:45 PM
5-SpeedFreak's Avatar
New User
what about 2
2"= camber issues, you can buy camber plates which can help to alleviate this problem.
Camber plates can create another problem called bump steer, not a good thing.
Bump Steer is when your wheels steer themselves without input from the steering wheel. The undesirable steering is caused by bumps in the road interacting with improper length or angle of your suspension and steering linkages.
Most car builders (ie: Acura/Honda) design their cars so that the effects of bump steer are minimal. However, make sure that you are always using the correct components for a particular car (springs included). Bump steer must be designed into the car and cannot be adjusted out if improper parts are used or if pivot points are moved without considering bump steer design principles
Hope this helps.
Old Dec 15, 2002 | 06:02 PM
01nhbgsr's Avatar
Default Re: how low should i go? (5-SpeedFreak)
i dont really know much about cambers and stuff, but one thing i know is that the wheel tilts out of the fender. so once it sticks out will it be fixable as in like you can make em stright again?
[Modified by 01nhbgsr, 3:12 AM 12/16/2002]
Old Dec 15, 2002 | 06:32 PM
burk's Avatar
you should get one no matter what. i had skunk2's with tokico illuminas. i lowered it about 2 inches and it wore the **** outta my tires on the inside. just spend the extra loot now, or youll just spend it on tires.
Old Dec 15, 2002 | 06:39 PM
01nhbgsr's Avatar
Default Re: how low should i go? (burk)
how much they go for?
Old Dec 15, 2002 | 08:31 PM
xteg95's Avatar
check http://www.groupbuycenter.com, they always got camber kits there. I think they usually go for 150-200. Gotta get one myself one of these days.
Old Dec 15, 2002 | 08:34 PM
majeed11's Avatar
Get H&R OE Sport Springs.... I gotta'em and love them. Just enough to not have any negative camber and they handle great, look great too. Its 1.7 drop
Here, some pics of my car: https://honda-tech.com/zerothread?id=360876
Old Dec 15, 2002 | 08:50 PM
Jesse H's Avatar
bad toe is what really kills tires, not camber.
Old Dec 15, 2002 | 10:41 PM
skeeter's Avatar
go as low as i had my front in this picture.. the ride is great ! .. LoL....
Old Dec 15, 2002 | 11:21 PM
jdmTegraLs's Avatar
1" or 1.5"
Old Dec 15, 2002 | 11:31 PM
SIK IN DA HED's Avatar
New User
who cares about camber? drop the biotch!
Old Dec 15, 2002 | 11:33 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: how low should i go? (dlplayboy)
skunk2 coils blow.
1.5 for me and i still ride like **** (with konis and a skunk2 camber kit)
Old Dec 16, 2002 | 11:20 AM
Brett's Avatar
Default Re: how low should i go? (dLo GSR)
I dropped mine 2in and it rides like ****, mad bump steer, tires are getting ate away, etc. It looks great but it's not worth the shitty ride and steering. I'd say go 1.5 or maybe 1.75 but not 2.
Old Dec 16, 2002 | 12:18 PM
TheHater
Guest
Posts: n/a
skunks
Old Dec 16, 2002 | 01:23 PM
YumYumRoLL's Avatar
at least 2 inch
Old Dec 16, 2002 | 08:51 PM
IntEGNYC's Avatar
1.5
any lower and you can scrape the gum off the pavement
Old Dec 16, 2002 | 09:26 PM
YumYumRoLL's Avatar
Default Re: how low should i go? (IntEGNYC)
scrape the gum off the pavement.. hahaha
[Modified by mr clean 4dr, 6:27 AM 12/17/2002]
Old Dec 16, 2002 | 10:10 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: how low should i go? (mr clean 4dr)
I'm lowered almost 2", no camber kit, no tire wear problems AT ALL.
Old Dec 16, 2002 | 11:54 PM
S2KGirlie's Avatar
down to the last coil!!!!!!!!!!
Old Dec 16, 2002 | 11:56 PM
BigCloud069's Avatar
Just scrape man! lol jp! Go as low as possible! I dropped my car almost 3 inches! no camber issues! my homie dropped his teg 2 and quarter! no camber issues! just drop the bitch!
Old Dec 17, 2002 | 12:09 AM
Tomek's Avatar
Default Re: how low should i go? (00SL1Whoo--er)
It all depends on your intentions, thats something we cant decide for you. Show? then drop it like it aint no thang
Performance? 1.5"-2"
Personally I ride on Eibach Sportlines/kyb agx and love the setup. Just about 2" drop after it settled and rides smooth as butter compared to a lotta of other peoples cars ive ridden in. The drop looks great and performance wasnt sacrificed for it, I havent had any major camber issues either.
Old Dec 17, 2002 | 12:44 AM
Ivan's Avatar
senior gold member
Default Re: how low should i go? (AztecEJ)
My car is slammed y0! I think its with what you wanna do with your car. I think a 2 in drop is perfect but I like my tires tucking y0
