What intake air temps have you seen while tuning your car?
I'm just curious to know what intake air temperatures you guys have seen while tuning your car. I'm guessing mine will be around 170 F. This is at 20 lbs of boost, air to air intercooled, a compressor efficiency of 78% and about 80 degrees (F) ambient air temp.
Post what you have seen, the boost pressure you were running, and the ambient temp if you remember it. TIA
water to air temps are arond the 60degree range when nitrous hits it drops to around 40 degrees. But most of the methanol guys have extremely cold burn but most of the air to air guys shuld see 110-140
jerryscherry
11
Aug 10, 2012 07:46 AM
